Cap/topper options
Bobbybob
Northern Colorado
Where do they source the 12v power from?
I will double check but I believe they wired it right off the tail light. This powers the remote lock on the latch, 24" LED strip, and two USB ports in the back. I asked about a conventional plug or a cigarette plug and they said it would have to wired a little differently. I think though that has more to do with the wire gage vs what they wire into.
RJS
For constant on power there's a 12v wire in the 7- pin trailer connector as well as brake lights if you have one. I used an adapter that fits between the 7-pin plug and harness to put power to my bed. I did change some wires around in the adapter but there's no cutting into the truck harness this way.
carpram1500
Hey RJS, do you know if there’s a way to make the 12v power source from the 7 pin trailer connector dependent upon the ignition? I’d like to use it to charge a secondary battery in my camper but don’t want to drain my battery under the hood if I park and forget to unplug the 7 pin.
BuiltToServeCeramic
New to this thread and just read through every post. Very good information! Does anyone have any more pictures of an ARE Z2? Was quoted $2495 and told the Revo and Evolve do not fit well on the new Rams and couldn't even get pricing? Any new Revos or Evolves out there?? Thanks in advance!!
stevegads19
Figured I'd post my new topper from ATC. Model is the LEX. 1500 crew cab with the 6'4" bed. All things remain stock on the vehicle right now aside from the topper.
RamSam
Thanks for the pics. Trying to decide what brand to go with and ATC is one I'm considering. Are you happy with quality?
BmoreStew
Just added a Lear with the slider windoors an am loving it so far. Being able to open up the sides and get to the bed slide side storage is great.
Quality of the topper is good, the color matching is good too, whomever was installing the windows rushed a bit, but it’s only noticeable if you’re looking hard. I’ve gone back and cleaned up or adjusted whatever I happen upon. Honestly though, It’s beyond my expectations... these things have a reputation for being slapped together and I had expected far worse.
The bed slide, BTW, is amazing. It, or something like it, should be a requisite for toppers
Bobbybob
Northern Colorado
I like the rear sliders on those toppers. I ended up going with a Snugtop but really wanted those windows in mine. Glad your happy with it, looks great.
1guyandtools
millerbjm
St. Paul, MN
I have always been a ARE guy (Z’s on the last two), but went with the XQ with Leer Locker this round. Due to the QC issues with the Revo, etc. I am OK with the looks of the Leer, but the Locker is great. Can handle almost all my bird hunting gear and emergency recover gear with no problem. Never will have another shell without it.
If you get the Leer Locker, make sure you go over and torque the fasteners to “spec” every so often. They will rattle loose. Someone failed to install the required lock-washers on mine and I almost had a series problem when I noticed one corner had vibrated off and was hanging gown about 10inches. At the time, two other corners were about 2 threads from killing the top.
You can get an ARE and then add a Cap-rack on your own, but you better be good at measuring.
Above all, I bit the bullet and got the BedRug all around as opposed to just the bed floor. Not sure of the benefits of the bed sides being wrapped in BedRug, but it really looks nice and is a benefit when you crawl in the bed or sleep in the bed.
What is the cap rack you reference? I have an ARE and looking at the leer locker it seems like a great addition. When I google cap rack I get results for ladder racks etc. Thanks!
millerbjm
St. Paul, MN
ARE CX series with screen sliders, led rope light, Yakima tracks and 3 place power supply (always on - wired to tail light I believe along with rope light switch). Also has a DIY bed drawer that I often remove for headspace when sleeping in the bed. I had a Z series on my 4th gen with auto-lock, opening side windows and drop down front window but didn't have as much expendable income this time around. I miss those features but still like the cap. I did have issues with leaking that the dealer solved with a tailgate seal kit and silicone on the bed rails but I am not super happy with that as it will need to be redone if/when topper is removed and re-installed.
stevegads19
I am very happy with the quality and overall styling after having it for a month or so now
LakesAZ
Northern AZ
I know this is a broad question but what does a topper go for? This would be for a short bed and any manufacturer is fine as I haven’t decided which one yet, however I am leaning towards Snugtop and Leer and A.R.E.
Bobbybob
Northern Colorado
They all have a base price and then go from there based on add ons. I have a Snugtop Rebel, which the base price is $2500.
Batlwagn
North Carolina
Just ordered a LEER 100XR with headliner, LED lighting, power port, front slider, side sliders with pet screens and it was 2600ish with tax. Add the bed rug as well and it was right at 3k
