nicodywill
 - Aug 21, 2018
ok?My truck and the loaner I have are both hemis, and I haven't ever seen this issue.
They also stated no codes showed on mine.May not be the same issue but worth considering if they haven't found anything. Mine had a bad fuel pump from the factory. It would long crank and not start. There were "some" times that the RPMs would be really weak upon starting and it sounded similar to what your describing. No codes showed however. They had to do a fuel pressure test to find the issue. Its been rock solid since the fuel pump has been replaced.
Mine is a 05/23 build date.They also stated no codes showed on mine.
What is your build date? My pickup is almost identical to yours.
I hope that’s the issue. It’s been great ever since.Hmm... mine is within a week of yours I believe.
I just spoke with my service adviser and requested them to run a fuel pressure test and verify everything was within spec.
Hmm, may explain why sometimes when I start it sounds like the engine is starved of oil for a few seconds... I'm going to use my 1st RAM care oil change tomorrow morning at 2,300 miles and see if that fixes it.It took 10 days for them to get a technician to look at it and he observed what I described.
I was told they found a faulty valve in the oil filter that was letting all the oil run out and into the bottom. They have since replaced it and are letting the pickup sit to have the truck go back to a "cold" state and they're going to see if that remedies the issue. I asked if this issue could have caused any potential damage to the motor and was told no.
I don't honestly know that much about the details of what I was just told so if anyone on here has any insight into if this is a thing or if I'm just getting lip service would be greatly appreciated.
Will update as more details become available.
I wouldn't think that's my issue, but I could be wrong - May build as well. Truck has no problem starting, just odd engine sounds on cold starts and that brief rough idle in the cooler temps. Once it's wamed up it's 100% fine - no issues with power or idle.May not be the same issue but worth considering if they haven't found anything. Mine had a bad fuel pump from the factory. It would long crank and not start. There were "some" times that the RPMs would be really weak upon starting and it sounded similar to what your describing. No codes showed however. They had to do a fuel pressure test to find the issue. Its been rock solid since the fuel pump has been replaced.
