I got my parts from eBay and got them installed by a relatively close dealership--Boyertown, PA. They quoted me $85 to install the parts and flash the computer. I made the appointment, took my truck in, and about an hour later I was on my way.
Thanks for the great write up. This is where I got stuck......the menu looks different on the new release for Windows 10. I was connected, but no little car. I sent an email to ALFAOBD to see what the issue is. If the Windows 10 steps are slightly different, I will post them up.
Once connected click on the little car with the hood up and navigate all the way to the bottom of this menu
Select "Car Configuration Change"
In the next menu you will need to make the following changes one at a time. Be sure to validate that the change was made by selecting each option and seeing what it is set at according to AlfaOBD after you set the option. The options you need to change and the values for them are as follows:
ITBM/HWM Integrated Trailer Brake Module: Change to "ENABLED"
Trailer selected CSM: Change to "Yes"
Trailer name CSM: Change to "Yes"
Trailer type CSM: Change to "Yes"
Zip ties work great, that how I did mine.Can I buy those screws and nuts anywhere else? Like in Walmart or oreily? I made order for parts, but forgot to add them in the cart.
Same here. Zip ties do the jobZip ties work great, that how I did mine.
Thanks for the great write up! Just installed myself on my 2019 Laramie.
I have the 6 person seating so it was a bit of a pain in the butt to get the controller bracket installed, but otherwise it was a very simple job.
I used the DT MY2029 PowerNet Var.4 in AlphaOBD on a cheap kindle fire and that step probably only took 5 minutes.
Mine didn’t do any of that after I installed the controller and module. Did you disconnect the battery? If so that’s what probably did it. I would let it sit for about 30 mins and try starting it up again.Just finished installing. It was really easy. Maybe took 30 minutes. However, after turning the truck on all of my setting were messed up. My climate control won’t select a temperature and instead goes straight from HI to LO. Also my backup camera doesn’t work. I’m certain I’ve hooked everything up. Is this something that screws the computer up until it gets flashed? I have an appt with the dealer. $45 for a flash!
Yes I did pull the negative cable. I’ll give it another try. ThanksMine didn’t do any of that after I installed the controller and module. Did you disconnect the battery? If so that’s what probably did it. I would let it sit for about 30 mins and try starting it up again.
Hey Lonestar,In my menu on the left side of your above pic mine shows a trailer when viewing the trailer brake. Yours shows you are on the fuel. Do you still have the fuel screen?
