Neurobit
RAM Sorcerer
Pretty good info. I've always enjoyed his videos:
Tuned for higher HP and slightly lower torque in a street application. The numbers would likely be quite a bit different in a truck (if they want the powertrain to survive). But don't get me wrong...that Shelby engine looks like a beast!My question is, how does Ford get 760 hp out of a 5.2 while Ram is only getting ~707 hp out of a 6.2. If Ford puts that Shelby motor in the Raptor next year, Ram's TRX reign as top dog will be very short.
There is less than a second difference from 0-60 and quarter mile times between the 702 hp TRX vs 450 hp Raptor at this moment. Imagine what will happen when the Raptor has over 700 hp.
True, but "seconds" is the wrong unit to look at when you're talking 4 or 5 seconds. Think percentages instead. 1 second difference when you're at 4 seconds, is absolutely massive. 1 second difference at 30 seconds is a rounding error.
Absolutely true. Though the rounding error can easily go the other way, since these times are based on FCA reporting and not actual independent test times. When these things are tested face to face in the same conditions we may see a huge difference or none at all, the TRX maybe even faster than reported or the Raptor may prove to be just as fast on road with vastly less power.
The weight difference is huge between these two, and a little bit more power is all the Raptor will need to close the door on any performance gaps. However, as an off-roader myself, I know that the weight employed by the TRX in the chassis is helpful for durability and stability on the rough stuff at speed. I think in the end, regardless of power, the TRX will have a distinct off-roading advantage over the Raptor, at least at baja type speeds and conditions.
Yep, we'll have to wait and see I guess.
But current Raptor owners still have to be somewhat miffed, even if the Raptor can keep up, I mean just think of the sound track; I have to believe each and every Raptor owner would prefer the sound of the TRX over that ecoboost, and sound is a huge part of the formula which even Ford knows else they wouldn't be piping in manufactured sound. They may not admit it, but most Raptor owers are going to be quite envious until Ford comes out with their own V8 which I'm sure they will.
The 6.2L Hemi I think is still based on a purshroad design, which has a torque advantage, the GT500 motor is a more modern dual overhead cam design, which has better hp. That motor produces more hp than the HC motor, but produces less torque.
The difference is also the weight, the Raptor weighs so much less, it won't take as much power to out perform the TRX, at least on the street. There is less than a second difference from 0-60 and quarter mile times between the 702 hp TRX vs 450 hp Raptor at this moment. Imagine what will happen when the Raptor has over 700 hp.
Of course that extra weigh was for extra durability off-road, there is a reason why Trophy trucks weigh so much. It does help with stability and durability, which will likely be the TRX advantage over the current Raptor. Can't wait to see them put head to head.
The Raptor has a sizeable advantage with it's lower weight, but it's still the ugliest truck currently on the market (other than the Tundra)
Apparently he has never seen the current Chevy twins
