BowDown
I think you're comparing 7 vs 7. Read what I wrote again:
"Put the 3.21 in 7th and it's exactly the same final gear ratio as the 3.92 in 8th".
Which it is. The number of 0.08 is the difference between 3.21 in 6 vs 3.92 in 7. Which means, more than likely, that at the same speed on the highway where the 3.21 is in 6th, the rpm will be equivalent to a 3.92 in 7. Same speed, same rpm, just different gear.
The same holds pretty much true across the last 5 gears, very minor differences.
The major differences are in first/second, and when the 3.92 has no more gears left but the 3.21 can then upshift to 8. If you're rock crawling a lot, by all means get the 3.92.
The point of my posts on all this is that the 3.92 is far less effective than some people think, because the 8 speeds give you so many gear options that you will be able to find overlapping gear ratios for the same rpm, just in a different gear. The numerical gear you are in is irrelvant, what matters is gear ratio at a given rpm, and that's my point; 6th (in the 3.21) and 7th (in the 3.92) have the same final gear ratio, so they will be at the same rpm at the same speed, giving you equal amounts of power at that speed, it doesn't matter that the one truck is in 6th and the other is in 7th.
I agree, its not complicated and IMO, the 3:92's advantages end after 2nd gear.
