Nails
Intake valve face inside combustion chamber, yes had carbon on itDid it pass oil through the intake, if so, take a look at the intake valve face
Has anyone done this on a V6? Are they as necessary due to the difference in combustion chamber design?
I don’t disagree, though that doesn’t seem to be a issue on gen3 hemis that I’ve seen. It’s possible certainly, again fuel entering chamber and flowing on valve will remove or drastically reduce that. Still the main concern is build up on piston top, chamber of head and valve faces.The valve face contacts the seat. The part exposed the chamber is the backside or back of the valve which I would expect to have carbon on it. heavy oil into the intake will cause a valve in the seat to rub together and create a groove on the face of the valve otherwise all the oil is going to do is affect performance.
www.mightymousesolutions.com
I'm currently swapping a 5.7 hemi on a 2014 ram with 90k. It lost a lifter and ruined the camshaft. Oil was like mud. I'd like to note the both the original engine and the replacement engine have alot of gunk in the intake manifolds.Thank you for the responses everyone I really appreciate them. So what I take away is this: It's not a necessity. It will help your engine long term but it's not going hurt anything if I don't do it either. I've had one engine have to have the top end replaced years ago due to sludge the push rods started to go. And I was doing the oil changes I just didn't use synthetic like they wanted me to. Fortunately for me they couldn't blame it on the oil so it was done under warranty. But the mechanic said it was due to not using synthetic in the particular engine. So I think I will install one when I get my truck this summer. Just as a preventative measure since the Hemi's are known to have a little more "blow by or whatever term you wish to use".
I work at a national laboratory... collecting samples and date is a daily life for me... and my oil samples, and catch can drain container sit on my desk and gets a lot of "oooh what is that" until they realize its just engine oil^^^^ I wish I would of saved all collection from start. Just for my own stats.
Quick question, what do you use to clean the oil catch can?
I consistently get about 1/2cup per OCI and considered sending mine in for an oil sample analysis but figured it was a waste since it comes from the same system as what is sampled in the crank case/oil pan. It is essentially the same engine oil sampled from a different location.I recently installed my catch can at 2000 miles on the odo, 3 miles after my first dealer oil change. now, 7012 miles on the odo, 5012 miles down, my catch can has collected almost exactly 100ml of oil/stuff. no solids that I can see, but definitely more oil than I was expecting. has any one else actually measured the collected material? I left it at work in a beaker for 3 weeks and had no separation so it appears that there is no artifacts of water or other fluids that would easily settle from the oil.
5.7 non e-torque (shouldn't make a difference though)
I have this system on my Corvette, gonna buy the same for the truck
Ram Gen 4/5 Hemi Mild | mmsolutions
PCV can set up with -8AN Fittings-connects between PCV valve and intake manifold-includes mounting kit, required push lock hose and -8AN fittings-if you do not think this mounting kit or fittings are best for you install, please go to the 'Build-A-Kit' section following this parts list as a...www.mightymousesolutions.com
