Bilstein 5100
texasvolfan15
I am thinking about going down the path of doing mopar UCA, bilstein from shocks at max height, and then a 1 inch rear puck so I can do 295/70r18 on a 0 offset rim. However, I was also wanting to get the bilstein rear shocks but it says it is 4WD only. Can I not use those if I have a 2WD truck?
FLArebel
I don’t see why that would be. I just did that same set up with setting 5 up front. Mine is 4x4 but I don’t see why that matters on the rear
FLArebel
Sorry for crappy angles/quality. I’ll try to get better pics on a flat surface. I just happened to have these in my phone
texasvolfan15
I reached out to bilstein and the rear is compatible with 2WD..now its a decision of is it worth it to get UCA, rear shocks (might be worth that no matter what) and then a spacer + installation cost. I think having just the little bit of extra height would look really good but not sure
mp1
SoCal
Just my opinion...but I don't see why you'd need a new UCA with just leveling the truck. May I ask what you're going to be doing that will require it?
texasvolfan15
So the plan was to do bilstein max on the front and a once in rear spacer with the bilstein rear 0-1 in the back. So basically an extra inch of lift around the board. But from what I've browsed it looks like you should get new UCA when you do the max setting
K_Hub
almost triplets!! I went with #5
This is next on my list. Would you mind providing heights at the front and rear wheel wells at setting #5 since your truck has settled? I’m torn between #4 and #5 because I’m not sure if #5 is going to give me enough of the rake that I want. I went two high on my Gen4 and definitely felt it at the pump.
westcoastram
I'm adding a 3.5" Ready Lift pretty soon and am wanting to switch to Bilsteins. Which model/part number should I choose?
Phlipnstik
I'm planning the same. Already have the 5100s and the 5160s and the tuff country 2" leveling kit with roller ball upper control arms but I'm still waiting on the rear ICON springs (Back Order). I'm still trying to figure out the math and what setting I want my front 5100s set at to get the 3.5 inch lift. Truck currently sits at 22.25 (Rear) from center of wheel to fender and front is at 20.75. That's only 1.5 inch rake but all level kits are 2". So do these level kits put the trucks nose high or is my truck just off?? If I add the rear 1.5" springs I will be at 23.75 in the rear. In the front, I will add the 2" top hat level from tuff country plus setting 3 on Bilstein (.90) that will put the front at 23.65" or should I put the front setting at 4 (1.3) which will put the front at 24.05. I'm pulling my hair out!! hahaha
Some 3.5 inch lifts have a 2" rear spring spacer, while others have a 1.5" rear spring spacer. What's the deal!?!?
westcoastram
Front 5100's adjustable = Part Number: 24-232203
Rear 5160's (L/R)= Part Number: 25-299267 / Part Number: 25-299946
Thanks!
I'm wondering what setting I should use with the RL? I see some guys not using the front spacer and only the UCA's etc. Then others using the spacers as well, so i'm conflicted. This is all new to me, so any suggestions and recommendations are welcome.
I just want a decent ride quality and the ability to do some light offroading.
NorthernArea51
NY
Just up front. Sitting now at just about 1/4" lower than rear (after settling in). No more rubbing on my ridge grapplers at full lock and going up/down the driveway curb in forward or reverse! :) Ride feels great to!!
I have bilsteins coming in 2 weeks. Seems like setting 5 avoids the nose high look? Are you happy with the setting?
BiGJZ74
American Canyon, CA
Thanks!
Posted this in other threads... My truck w/ 5100's @ #4 with RL 3.5" kit no preload spacer and 5160's in the rear on 35's
K_Hub
Where’d you find yours? I can’t find them in stock anywhere.
NorthernArea51
NY
RealTruck. Gave me a delivery date of 8/14-18. JackIt was telling me 4-5 weeks.
Phlipnstik
That's with the 2" spring spacer in the rear correct? Any Rake or is it level? I'm only going up 1.5 in the rear with the ICON springs so I may have to go setting #3 up front. If you have a 1/2 inch of rake I can go with #4.
Phlipnstik
I tried that. Back ordered is what the website told me
Did you get on their wait list? I had to do that. As soon as they come in the will email you. You need to order quick or they're gone.
