OldMarine
- Feb 29, 2020
ok..did my first oil change on the Ram today...looked it over first underneath, and figured I would see what I could come up with to keep things clean. Did a mod to a little plastic scooper, and whaddya' know...worked like a charm. I mean, not one drop on the sway bar. View attachment 59566
So I don’t have my Ram yet but this trick worked awesome on my Mazda Miata for the oil filter above the subframe. See pic.now...the OIL FILTER is a whole different problem...what a joke! Will be working on that mofo next.
Well done!ok..did my first oil change on the Ram today...looked it over first underneath, and figured I would see what I could come up with to keep things clean. Did a mod to a little plastic scooper, and whaddya' know...worked like a charm. I mean, not one drop on the sway bar.
the Oil Filter...HA HA HA...ya...that F-in oil filter. I have NOT solved that yet, but I will! lol...I'll report back when I get that riddle figured out. would like to drop-kick the sorry "engineer" who gave us that..Well done!
Now. What about the oil filter? If your RAM is 4x4, I'd sure be interested how you solved that one, what with the steering gear and front axle blocking access.
Steve
oooooooh..I like that idea. Pretty sure the RAM filter will fit a Solo. It's not very big filter. Will be trying that next time. Thank you!So I don’t have my Ram yet but this trick worked awesome on my Mazda Miata for the oil filter above the subframe. See pic.
Will the filter fit in a solo cup like I posted above?
Pretty neat. Only issue could be the tapered bottom. When I do the Miata there is a lot of oil that gets in the cup while it is loose and you wait for it to drain. Then there is the concern about splash when the filter finally releases and drops into the cup. The Miata filter didn’t drop all the way in, but I had to bend and distort the cup a bit to get the entire thing out of the car. I’ve only done this once to be honest. It worked well. I think a 2nd time will go better, especially if I don’t tip the cup over full of oil while taking a photo!I've been using a quart size zip loc bag, but I still spill a little oil. But you guys got me thinking about trying a collapsible silicone cup, like these...
China Silicone Drinking Cups Manufacturers and Suppliers - Wholesale Silicone Drinking Cups - Legenday
Wholesale the high quality and effective silicone drinking cups from professional manufacturers and suppliers here with Legenday at legendaychina.com. We also support customized silicone drinking cups. For free sample, contact us now.www.legendaychina.com
Just a matter of finding the right size. And the silicone will make it easier to grip the filter when spinning it off.
I agree about the taper being an issue. There are lots of sizes and variations of these though, and I'd be surprised if there isn't a size that will work. I'll probably have to try several sizes until I find the one that works best. Or until I decide it won't work any better than the zip lock baggiePretty neat. Only issue could be the tapered bottom. When I do the Miata there is a lot of oil that gets in the cup while it is loose and you wait for it to drain. Then there is the concern about splash when the filter finally releases and drops into the cup. The Miata filter didn’t drop all the way in, but I had to bend and distort the cup a bit to get the entire thing out of the car. I’ve only done this once to be honest. It worked well. I think a 2nd time will go better, especially if I don’t tip the cup over full of oil while taking a photo!
What about this? Don't have it but figured I'd see if something like the two above statements already existed.
2019 Ram 1500 Laramie 4x4 - Crew Cab/5.7 Bed - 5.7 Hemi - 3.92 - Anti Spin - Level 1 Options - RamBox - BUG
Then maybe a modified cup with a hose. Unfortunately I've never changed the oil on a ram. I've only heard stories. That is nuts it drains that much oil out. I've never had another car do that. I've changed my own oil on all previous vehicles. Usually the only oil leak is because the filter isn't mounted straight. I do miss my s-15 Jimmy. It was 4x4 and there wasn't room for the filter which forced them to relocate it. So it was in the front corner of the engine bay accessible from up top. My Frontier was mounted on a 45 so they installed a trough to catch the oil.
In the past I have used a plastic shopping bag to drape over the steering rack when removing the oil filter.now...the OIL FILTER is a whole different problem...what a joke! Will be working on that mofo next.
