Toggle Switches
Here is how I handled the mounting of switches. B382102D-FDC5-4C34-A507-D6D93DBA0AF8.jpeg
I 3D modeled a switch pro mount that uses the CD player as a mount.
Finally found a solution for switches that I am happy with! Did not use the CD player at all so I removed it, cut a piece of black ABS to fit into the hole and wired up a push button switch.
What switch is that?
That's how I did mine. I found that spot to be useless for anything else.
Just finished setting up my swithpros. I mounted the switch panel to the proclip cell phone mount that clips onto the vent and ran the wire in behind the center screen. No drilling any dash panels so all is reversible.
This was a great read. I was wondering those with the multi switch panels, do you have it tapped in somehow to turn off when the truck is off? If so where did you tap into? I am looking to add some lights soon and want to be ready to go once I start. Thank you really enjoy this group for all the help.
I am running the Voswitch UV-100. Its another 8 button switch panel. It is however programable (each button can be momentary, strobe, emergency flash, normal on/off) I have mine currently running into the ACC on fuse so it will shut off when the truck is off. Currently have two lights, compressor, and horn connected. It is a little more than amazon boxes, but less than switchpros. The only reason I went with this was for the ability to program for momentary.
Do you happen to know which one, the ACC is?
Thank you very much I appreciate the help.
Any tips to make this a perfect size? your's looks pretty good.
update...
