That link didn't work for me.Will be using this, may be overkill for just 1 set of lights, however also utilizing it for emergency lighting setup
What switch is that?
I am running the Voswitch UV-100. Its another 8 button switch panel. It is however programable (each button can be momentary, strobe, emergency flash, normal on/off) I have mine currently running into the ACC on fuse so it will shut off when the truck is off. Currently have two lights, compressor, and horn connected. It is a little more than amazon boxes, but less than switchpros. The only reason I went with this was for the ability to program for momentary.This was a great read. I was wondering those with the multi switch panels, do you have it tapped in somehow to turn off when the truck is off? If so where did you tap into? I am looking to add some lights soon and want to be ready to go once I start. Thank you really enjoy this group for all the help.
Do you happen to know which one, the ACC is?I am running the Voswitch UV-100. Its another 8 button switch panel. It is however programable (each button can be momentary, strobe, emergency flash, normal on/off) I have mine currently running into the ACC on fuse so it will shut off when the truck is off. Currently have two lights, compressor, and horn connected. It is a little more than amazon boxes, but less than switchpros. The only reason I went with this was for the ability to program for momentary.
Thank you very much I appreciate the help.Hard-wire Dash Cam Install
I had this setup on my F150 and just finished the install on my RAM. I run a Viofo A129 dual dash cam, with the rear cam mounted on the passenger side of the sliding rear window (cable tucked up inside the headliner on the passenger side. Dash cam -...5thgenrams.com
Can you share that stl?Here is how I handled the mounting of switches. View attachment 59161
I 3D modeled a switch pro mount that uses the CD player as a mount.
