I just checked mine (build end of January 2020) and I do not have the reservoir either. Bit of a bummer.
This seems to be a question that needs to get answered. What are the trucks "supposed to have" with and without Air Suspension and how to resolve it if you don't?
No air suspensiondo you have air suspension?
Bilstein makes good shock and the non reservoir shocks should be sufficient for most users, but it’s not what we paid for or what we were told our trucks had. I drive a lot of logging roads, sometimes hours at a time and that extra oil would help with shock fade quite a bit.
While I do agree that non-res shocks are sufficient... and I have zero complaints... if our trucks were supposed to come with a certain part number, but didn't, even if these different ones are within spec... that's an issue.
^^^ I agree. I have them, but don’t have the air suspension. I see that you have the EcoDiesel, and I have the HEMI w/o eTQ. That would be odd if that was the reason. I don’t have the Trailer Tow Group. Maybe it’s the two-paint optionJK. As mentioned, a supply shortage make the most sense, but that should be documented somewhere...
Mine were listed under Standard Options
This seems topical... from the launch press release of the 2019 Ram 1500... emphasis added by me.
Also new for 2019, the Ram 1500 Rebel is even more capable, now available in Quad Cab configurations and featuring new 18-inch wheels with Goodyear Wrangler DuraTrac 33-inch tires driven by an electronic-locking rear differential. The Rebel predecessor came standard with Ram’s Active-level four-corner air suspension and a one-inch suspension lift. While air suspension is still available, the new Rebel comes standard with coil spring suspension and a one-inch factory lift. Newly designed Bilstein shocks feature remote reservoirs to keep the shocks cool and work with unique rear suspension geometry (Rebel and 4x4 Off-road Package) to keep the tires in traction. Rebel also includes Hill-descent Control for more off-road prowess. Hefty tow hooks feature wide bumper openings to ease use and the underbody protection features skid plates on the transfer case, steering system, oil pan and gas tank.
Source:
FCA US Media - Press Kit: 2019 Ram 1500:null
embargoed.fcanorthamerica.com
