2019 RAM 1500 hellwig swaybar
Mch5jdm
Michigan
Does Hellwig keep their prices the same for all distributors? Everywhere I look it’s 269.30. Where’s the best deal?
Stevenc150
Bought mine here at discountbandit.com (was $234 last wk)...its tax-free, shipped faster than Amazon, and shook out cheaper for me...
Scram1500
Put a bar in it and bend it straight.
If it could be bent, it wouldn't act as a spring. The only way to bend spring steel is to heat it to 1700 degrees F, which ruins the temper
Rambro23
It's on both sides to keep the bar from moving side to side for extra stability. I have the lifted version, it may not come with the non-lifted sway bar.
Thanks! Makes sense I don't have that piece with a non-lifted truck.
Mch5jdm
Michigan
Installed My Hellwig and timbrens!
chrisnack
Madison, WI
Towing with the Hellwig sway bar.
I have an Outdoorsrv 24kts dry weight is 6200lbs, loaded for a week of camping with a full tank of water 7300 lbs .
The truck tows the trailer ok with the stock sway bar, but after adding the Hellwig set on the middle setting the truck handles the load much better. Prior to the installation of the Hellwig the trailer felt like it pushed the truck around. When you would enter a turn at speed it would always have a secondary steering input. After installing the Hellwig its like driving normal. Just turn in and its solid and stable. Before the Hellwig I would always drive at 60 mph or less to try to stay in the comfort zone, now I find myself driving 65-70 mph. I have to make a conscious effort to stay below 65mph. Thanks Hellwig
Awesome, just what i needed to hear! I was super unimpressed with how this Ram tows our camper compared to my previous F150, way bouncier and pushes the RAM around a lot more. So i guess i'll be ordering this to help out.
What setting do you have the bar on?
GraniteRam
He said middle setting.
chrisnack
Madison, WI
Sway bar ordered, we'll see how long Amazon takes to deliver it.
Also picked up a Gen-Y Torsion hitch. Hopefully the combination of those 2 will make the towing experience better with our camper.
TTT123
Could someone tell me if I need the normal hellwig sway bar or the one for 2-4” lift? I have the revel performance links and daystar leveling kit. I figured the lift one but just making sure. Thanks
Ellisstrong
Atlanta Ga area
You need the regular one unless your rear end is lifted.
Neurobit
RAM Sorcerer
Texas
I believe that If you have a 4” lift or higher, you will need the extended links.
