2019 RAM 1500 hellwig swaybar
Hey guys
I got a 2019 Laramie Crew 5.7L 4x4
I just got back from Hellwig to let you know about their swaybar setups. We confirmed that the previous generation swaybar fits the 2019 like a glove. The ride quality has improved a lot and feels so much more stable in and out of corners. The swaybar is a lot more beffy and solid compared to OEM which comes hollow. Definitely recommend the product. Here are some pictures
Jared B
Site admin
Vancouver B.C
I think it's awesome that you're modifying your truck already and reporting back to us with your upgrades. I know the Hellwig swaybar had some good reviews for the 4th gen trucks and have been considering picking one up myself.
Glad you like it!
Beastram
Campbell river
Hey guys
Is that on air suspension or just the standard coral shocks
PorBoy
Millville NJ
Just received an email from Hellwig stating they have no part for our trucks. So what am I missing folks so that I too can join in having this part please.
PorBoy
Millville NJ
Oh wow so even though I contacted the company and they said they have nothing, a 4th generation one actually fits. Well that’s great news and my apologies if I came off the wrong way...
Jared B
Site admin
Vancouver B.C
You didn't come off the wrong way at all, no worries. (y)
PorBoy
Millville NJ
Thank you as sometimes when your typing on the forum, your true intent may come across the wrong way. :)
PorBoy
Millville NJ
Will I need the adjustable endlinks for them ? I was sent two part numbers from Helwig, one for the sway and one for the adjustable endlinks.
Accountant
CA
I think you need the end links if you don't have the OEM sway bar.
Pnorth
Sweden
I’m going to grab them both and if I don’t need them, I can always ship them back.
You want the end part - where you see the sway bar link is fastened - to sit level with the ground - flat - and since you have a 2" lift you most likely will need the adjustable links to achieve that.
PorBoy
Millville NJ
I placed the order and the sway bar will arrive on Saturday and the end links next Thursday lol.
PorBoy
Millville NJ
Thanks, I know that one is for a 2wd vehicle, but with mine being 4wd I have to wonder what would be different ?
PorBoy
Millville NJ
Now see that drives me crazy lol as really if it’s a novice looking to buy, they would be put off since it states 2wd. Thank you for the updated information.
Accountant
CA
Installed mine today. Some observations in the install:
1. I used an 8mm socket on a breaker bar to hold the end link bolt while I used an 18mm ratchet to loosen the nut.
2. Seems to be some corrosion under the factory bushing on the axle so to be safe I sprayed some black rustoleum over the stained area. See pic below.
3. The bushing bracket from Hellwig needs some wiggling to line up the bolts. Just take your time so as not to cross thread the holes. I probably just got some poorly made brackets in my kit.
For now I set mine at the outermost hole (softest setting) and will see how I like it.
Pic of orange stain under factory bushing
Painted with black rustoleum
