Wind noise
Adrianp89
I've said it before and I'll say it again. If you have the whistle noise, go the lemon law route. It will take a few months but it seems to be the only solution. This is a very winnable case and you can do it without a lawyer.I am under a NDA so can't give much more details but it is well worth your time.
Based on experience in this thread, even if FCA offers a buyback they do not follow their word. You need to have the State AG involved to push them, the longer you wait to do this, the longer you wait for a new truck or resolution.
TopwaterTX
I had the highway speed / cross wind whistle as well. After leaving my truck with the dealer for over 2 weeks, they identied the front door seals as the problem.
Like others have said, you can feel the seal vibrate when the whistle happens at highway speeds.
I am happy to report that my truck’s whistle issue appears to be fixed for now.
Hrspwr88
What did they repair/ replace.
Nibis
I used about 18” of backer rod
first photo just shows that it’s not causing the door to bulge out any.
2nd and 3rd photo shows the backer rod tucked behind the door weatherstripping.
Last photo just showing how the weatherstripping looks without pulling it back. You can see just sliver of the gray backer rod.
I have wind noise at highways speed too, thanks for posting this. Seems like FCA needs to revise the seal. So far I'm liking my truck, but the wind noise is annoying. I'm heading to the hardware store tomorrow !
bskubon
Just got a 2020 Limited 1500, drivers side view mirror (towing mirrors) has this wind whistle when above 45 mph. If I hold my finger on the mirror casing or mirror itself, whistle stops. What ya think? Dealer need to replace that mirror? Passenger mirror does not do it.
RamCares
Michigan
Hi @Nibis & @bskubon - I apologize that you are experiencing this concern with your trucks! If you decide to address this with your dealers, please be sure to follow up with us via private message. I would like to escalate cases on your behalf so that a specialist can work alongside both you and your dealer to exhaust all available resources in addressing this concern.
Mark
RamCares
Nibis
Mark
RamCares
Thanks, it is annoying, still trying to pin point the cause.
LawnD4rt
There are allot of posts about different wind noises here. Mine is the door seals from a cross-wind at Texas highway speeds 75++. Is there an official fix from FCA for this?
Rob_Dog
Is your noise the tea pot/Morse code sound?
Rob_Dog
I did the 3/8 backer rod shoved behind the weatherstripping on the door like one user said and it fixed it. Drove it in the rain as well and haven’t had any leaking or anything.
Is this a fix for the tea pot/Morse code noise or a different whistle?
Billy Blair
The loaner I have is 2019 5th gen and it does not have any sound. Its really quiet. The only difference is its a 4x2.
I have a 2019 Bighorn 4x2 and have the noise. The dealer has replaced both door front door seals to no effect.
moter3d
I have same truck. this noise has been interm since 3000 miles. its worse at 70 mph, slight crosswind from either side. I find that if i close the mirrors ths noise goes away.
Mgoins1325
Ram care specialist I have had this same issue for over 8 mos just kinda ignored it as it happens on windy days when on the highway but it is to much. I will be taking my truck to the dealer. Please let me know what I need to do to get this fixed. I am In sales and drive clients and this is horrible for conversatio.
RamCares
Michigan
Thank you for taking the time to follow up with me, I just had a chance to respond to your PM!
Mark
RamCares
crisRatliff
Does anyone else have the whistle at 45mph with a cracked window? I've got the 75mph and or high wind noise, but my whistle starts at 45 mph when I lower any window about 1 inch. Dealership says it is the fresh air vents...no fix available. Ram customer service has no solution either... can't believe that a $70k has this kind of problems...
moter3d
i was able to record mione last weekend. This is 70 mph on heading south bound I35 central TX. slight cross wind from the west
If i retract mirrors the noise quits
