I found them at Advance Auto.Where are you all finding the micro2? No one has it local all I have now is online
Routed my wiring next to the upper radiator support, where the hood latch is. I just followed the wiring there and the hood latch cable over to the Drivers light and battery. I used zip ties, but waited to cinch them down until I was sure it wasn't near something hot or sharp. Only had to cut one off before I was finished with the location. Sorry, didn't take any pictures before I put the top shroud back on.Hopefully my last question, where did you all route your wires?
There’s a lot of options and I’m just wondering if I didn’t miss a hidden spot
Found them at AutoZone, they’re “ATR” fuses, skipped right over them looking for micro2. I’m in business now, just waiting on my delayed LEDs.Where are you all finding the micro2? No one has it local all I have now is online
Which Lasfit’s did you buy? I was looking into the LA Plus.Also have the Lasfit LEDs installed so will see how they look.
I bought the LC6. Was like 60$ for 4 bulbs on eBay. All of their bulbs are cheaper on eBay, though. Still ship super fast, reach out to you to confirm fit, etc.
Same ones I bought too, doing my install tomorrow morning. They arrived within a day of ordering and their prices are definitely cheaper through EBAY compared to their site. How long was your install?
				I have the same work bench except with black top. The wheels making it mobile is a bonusInstall took me probably 4 hours, taking my time. I did it with a cheapo socket set, no wrenches, in my driveway - meaning literally anyone could do it. One thing I would consider if you have room is leaving the two fascia attached the grill. Partially broke both clips taking them off. Below post is where I saw it, would’ve done that if I saw earlier. Picture of my ‘workbench’ for laughs.
Headlight removal
So.....removed the headlights today, what a blast that was! :eek: This is not meant to be a thorough walkthrough, but a simple guide. Pics are from a '19 Ram 1500 Laramie Sport with the mid level LED lights. I would assume the process is the similar for all models (non flare equipped...5thgenrams.com
Watch video in post139 it shows where to install fuse tap.Maybe I missed it; where is everyone tapping into an ignition source ?
Thanks; I must’ve missed that one...Watch video in post139 it shows where to install fuse tap.
Everything was normal for me.Anyone get a “Service Airbag” message or have parking sensor issues after install?
It’s a fuse issue. I pulled the DRL wire and put all the fuses back to original and all my problems went away. Now I need to figure out a new fuse to use. Can’t use F38 or F60, it doesn’t like either of those selections. I have “F17-Air Suspension” which I don’t have on my truck, I’m only concerned about it drawing power and killing my battery. Any ideas guys?Anyone get a “Service Airbag” message or have parking sensor issues after install?
	Don’t do F60 my truck wouldn’t run with it there put it to F38 as recommended and it’s fine. Only problem is my projectors aren’t illuminating? Turn on my highs or lows and nothing. Turn signals etc work. I put LASFit H7s in there so wonder if they’re not clocked or something? They’re connected properly![]()
