Update: DO NOT BUY RAM WITH RAMBOX - Warping and Alignment Issue with 2019 Rams
Ellisstrong
Atlanta Ga area
Here are the "before" shots. I'll send the afters tomorrow. I am not sure where to get part numbers. Perhaps the body shop will send me a copy of the paperwork. All I did was sigh a paper when I dropped it off, and another when I picked it up.
Yeah one of mine looks at least that bad so I’m definitely interested in this fix
natsb
Here are the "after" shots. I don't see any part numbers anywhere. Any particular shot you want to see?
Eltaco
Curious where the steel clamps and screws are located? Mine look identical to your pics on my 2020 Ram, which also has warped lids.
natsb
Under the plastic maybe? I did take the truck back the day after I got it because the top corner was sticking out again. The technical came out with a screwdriver and wrench. He took about five minutes to get the corner back in. He said " This is a lot easier since they got rid of the tape and use clamps and screws now."
I tried to watch what he was doing, but was told to stay back six feet and put a mask on. I didn't have a mask, so I had to sit in the truck.
On a sad note, he said he fixes so many RamBoxes that he can do it blindfolded now.
Kxlexus
Kentucky
Be really nice if someone could find a FCA document or Star case we could point the service managers to and say;”do this” That’s about the only chance I have of getting mine fixed
Zeeya
Lafayette, LA
Build date 5/19. Mine clip in as those do. One side replaced - just the top and painted panel. I had to loosen screws around lid on painted section, pull out and push in at top to get it to snap into clip. Lowered and tightened back up.
top plastic panel was already on, maybe something under there
mikeru82
The Palouse
This thread has died without a resolution, so I'm bumping it. Do you have contact information for this tech or dealer he works for? You don't have any helpful information for us here and I'd really like to see if mine can be improved. My dealership is clueless about what to do to fix it.
Did this fix the fitment of your lids? I'm not really following what you're saying there. Did you replace anything?
Zeeya
Lafayette, LA
Dealership replaced the top section which is the hard plastic and frame of lid. They re-used the original painted section and clipped it onto the new upper part. It is (was) better, but it is warping as well. This is a before replacement and after replacement picture. Like I mentioned. The replacement is starting to warp now, but has not reached the level of first picture
Bluesurf
I believe that FCA must fabricate an all steel or aluminum compartment door and accept their cost saving failure. If they scrap the all plastic doors there will be no warping.
Willwork4truck
SC
Sounds right. Plastic just isn’t going to work well when beside a sheetmetal panel. Too dissimilar in materials and how they react to heat/elements.
mikeru82
The Palouse
Thanks for the update. I'm sorry to hear they're starting to warp again, but if they just replaced with the same parts, the same thing is going to happen to the new parts. It's already been mentioned many times in this thread...bad design and no apparent concern to fix it the right way.
mikeru82
The Palouse
My dealership said they weren't aware of any new fixes for this when I went in a couple weeks ago. Other than replacing the black section of the lid. Also said they're reluctant to even try to adjust anything because they don't want to exacerbate the problem. I said "no worries, I wouldn't let you anyway" LOL.
ywhat2002
I was told if you remove box assembly there are shims that need to be removed under boxes. Some need one front or one rear shim removed to correct lid to body alignment.
Ellisstrong
Atlanta Ga area
I need at least one of mine fixed. I’ll definitely bring it up the next time I’m at the dealer.
Kxlexus
Kentucky
That won’t fix the problem of the warped tops. Has nothing whatsoever to do with the top part of the lids curling up on the ends and separating from the rest of the lid
MF2020
Clifton Park NY
Agreed!! Although mine are not bad and certainly functional as is, it would be nice if they aligned better with the vehicle. This being said, it is still one of my all-time favorite features of this truck. Had them on my Ram 2011 and learned how valuable they are then. Now we have power and lights and auto locks, so really quite improved from the original design. But you have said it best here, time to take these things to the next level and get some kind of "metal" in these RamBox covers!!
mikeru82
The Palouse
I'm not going to hold my breath on this one. Maybe if is was a more popular option they'd be more interested in fixing it. But I can see it being more cost effective for them to stop offering the option and ignore the complaints. Hell, at this point I'd gladly pay for an aftermarket part to fix this. I'm happy with the rambox option, I would be even happier with it if the lids aligned correctly.
