Bed Step Install Doc and Pics
MValdez
North Wales, Pa
I know I have asked this question before but does anyone have the bedstep on their truck and also have the magnaflow exhaust with 5" dual tips and do they have any issues with the step's clearance in its closed position?
Ellisstrong
Atlanta Ga area
What magnaflow are you asking about specifically? I’m not sure if mine has 5” tips or not
mike12193
Yup I have the Magnaflow. It does make contact when you retract the step. It is kinda violent so I took a grinder and took a bit off the step on the piece making contact. Not it was only making contact when closing, when fully retracted it cleared by about a 1/4 inch. It is much better now and I can retract it without watching the left tip shake and slam.
John
Mine did, so I went to a muffler shop and had them "massage" the pipe a bit. No more contact!
John
MValdez
North Wales, Pa
*And this is why I love this SITE* -Thank you. I like the grinder mod.
Tvk999
I installed the amp bed step and I'm happy with it. Paid 260 it arrived in a couple days from auto accessories garage. Installation was easy. be advised you do have to substitute of the M8 bolts for a longer one 44 millimeters Will do it nicely. Easy step up and down plenty of surface area.
I have the AMP here and I am trying to install it but can't figure out where to attach the supporting bracket ... could you post a pic of your install ? Many thanks.
DennisY
Check the pictures on Page 1 of this thread and see if they pertain to your step.
Sixxshooter
I have this step coming to me tomorrow and plan on installing this . my question is do I really need to buy torque wrench To install this ? I have a **** load of tools because I’m a HVAC mechanic by trade but never got myself a torque wrench . Are we using it for removing the existing bolts or for tightening them . I’m pretty confident in my strength .????
Ellisstrong
Atlanta Ga area
I installed mine without a torque wrench initially and used it for about 9 months until it got replaced and never had an issue
Jako
Borough of Parks
Just finished install on my Oct 2018 build. The two long bolts starting to rust (little disappointed) so a little effort taking out, cleaned up with a red scruffy pad and went in easier. I didn't use any WD40 or such as I wanted a proper torque, 13/16" or 21 mm, 12 pt makes it a little easier than a 6 pt if using a breaker bar as that was all I had at the time. I wasn't plannng to install and after taking a look decided to throw it on with my limited supplies. Torque up later.
Nice addition and helpful when cleaning and conditioning tonneau cover. Thanks to all the previous posters.
Update: I did the 124 ft/lb torque on the bolts and must say that was some serious cranking down under the truck. I was having trouble getting the "click" at 124 ft/lb and thought I might have something wrong with my torque wrench. I backed off to 110 and worked my way up, nothing wrong with the torque wrench, just needed some serious cranking.
smoke8r
ontario
Nibis
Installed the factory bedstep a couple of weeks ago, no contact with the Borla 5 inch tips. I love the step, worth the money. My wrench did slip off the bottom bolt and i slammed my knuckles into the spare tire shield. My finger still hurts, LOL
Ortiz7983
But how is the wrench doing?
Jako
Borough of Parks
It's in time out
That's the problem today, no individual responsibility, it's the wrenches fault.:)
Hope your hand is doing well.
Thought I popped my hernia operation cranking down with the torque wrench to get to 124 ft/lbs.
MF2020
Clifton Park NY
Right?! That is a hell of an angle to work at under the vehicle trying to apply enough muscle to get 124 ftlbs!!! LOL. I just did it myself not too long ago and practically ripped the muscles in my shoulder doing it. A lift would have made all the difference!!
