Ellisstrong
Do you have an aftermarket exhaust?I just had the MOPAR 82215289AH installed and as long as you put the small bolt in first, followed by the two reused bolts up top...it easily clears the exhaust, even with the hardest kick closed.
		 . I read this entire thread before I put it on. Went on no problem other than the dirt that got in my eye because I was being dumb and not wearing safety glasses. When you disconnect the wiring harness, you have to pull that red clip all the way out. I thought it just pulled out a little bit, but it slides almost completely out. Aside from that this is a pathetically simple install, a lot simpler than the one that went on my Titan was. Works pretty good and I'm glad it's on the driver's side because I can't really push off with my right leg any more after breaking my knee cap and shredding the tendon last year.
