My truck is stock and I'm planning to keep it that way (with the exception of Line-X and a tonneau cover). I do want to gradually upgrade from halogen to LED bulbs. I wasn't going to fool with the interior lights but I ordered 194's for the license plate bulbs and apparently they're already LED so I decided to use those bulbs for the footwell lights. Also received my hitch and hitch pins.
IMO, LASFIT LEDs is the way to go. Night and day difference interior and exterior. I have changed all my lights except high beams and absolutely love them.
@Cease11 will do. I think it’s a bad thermostat. But they can’t look at it until next Monday!
so then Not stock?
Took it to the dealer because it started over heating. It only has 3855 miles on it!!!!
I am very sorry to hear this, @Mustangmike66! If you are at all interested in the additional support of a case specialist, please do not hesitate to follow up with me via PM. By escalating a case for you, this will provide the dealership and yourself with an individual who will review your concern, then assist you and the dealership in exhausting all available resources to have the concern addressed and resolved.
Mark
RamCares
Continued my chrome delete journey. 2 day project including cure time.
Supplies
Before
After much wet sanding
Primed 3 coats.
Painted 4 coats
IMG_20200427_121251.jpgIMG_20200428_111256.jpgIMG_20200428_111307.jpgIMG_20200428_111326.jpg
Overall happy with the outcome. Time will tell how well they will hold up.
UPDATE:. This process did not work out so well for me, paint started peeling after two weeks. Not sure if didn't apply the coats properly or what. I got them powder coated instead.
I'm thinking about doing something similar, what type of prep to get it to adhere to the wheels?
Pretty simple prep, cleaned first with regular windex-style cleaner, then with spray soap/water mixture, then final wipe with alcohol wipe. Used the wet method to apply decal using water/soap spray mixture, made it easy to adjust into final position. Then smoothed out with decal tool (felt side), did this once with application, again 30 mins later. Got lots of practice from the hood decal last week, but the wheel decals were WAY easier:
Here's the kit I bought on amazon for the big decal, all you need for the wheels is the blue/black application tool.
