z0n3
- Jun 16, 2019
The 7883 model came with the upgraded end links and those collars.Did it come with those locking collars, or did you add them?
PIA to remove them?Plastidipped my front tow hooks red.....
Installed Mopar Ramair intake and Mopar exhaust with 5" tips. All pretty east, but definitely would've been easier with a lift!
can be. just loosen the bolts (two bolts on each tow hook), dont take them all the way out. then you push the tow hook from the front of the truck towards the rear. They will pop out. The bolts were really tight from the factory. gunna need an impact gun or a bar with lots of leverage.PIA to remove them?
Thinking about installing the Hellwig. I don’t anticipate towing very often, but I’ve heard it makes the truck a bit more stable in turns. The ride is already great and I wouldn’t want to do anything to change that. Can you give us your thoughts on how it’s affected your ride? Thanks.
The sway bar is awesome except the bushings are squeakyThinking about installing the Hellwig. I don’t anticipate towing very often, but I’ve heard it makes the truck a bit more stable in turns. The ride is already great and I wouldn’t want to do anything to change that. Can you give us your thoughts on how it’s affected your ride? Thanks.
Buy it, it is an upgrade to your stock suspension and will ride better than stock. I have mine in the firmest setting. If I had to describe the feel, is it made the suspension feel heavier?!?! Hard to explain. You have to experience it.Thinking about installing the Hellwig. I don’t anticipate towing very often, but I’ve heard it makes the truck a bit more stable in turns. The ride is already great and I wouldn’t want to do anything to change that. Can you give us your thoughts on how it’s affected your ride? Thanks.
Thanks...I did grease the crap out of it and lasted about a month...Maybe this time will be better!Just installed mine and no squeaks at all. I pregreased the bar and the bushings preinstall with the grease that comes with it. I have used this ----> https://www.amazon.com/Energy-Suspension-9-11104-FORMULA-PRELUBE/dp/B000MW5SJ4 in the past with success. It's the same stuff the Hellwig comes with. Superlube works as well, it just doesn't last as long.
I heard they are notorious for that....oh well...It was def needed with my lift.I'll keep an ear out on mine then, just installed last week, thanks. That grease is super sticky, wear gloves when handling it, and if you don't WD40 or similar will break it up off your hands.
That's a good looking truck, lose the Alabama plate and "Roll Tide" and it will be a great looking truck. Geaux Tigers!Installed 2” leveling kit and put 33/12.50R20 ridge grapplers on. The 20x12 wheels were off my old truck and had 285/50 420’s. Rode around for awhile with those but they were useless off road. View attachment 53293View attachment 53295View attachment 53296View attachment 53298View attachment 53299
What's the interval on those?Changed out my cabin air filter my old one was really dirty. Made a install video
