14" Magnaflow w/ resonator delete
UNKALJ
Sound clip after removing the 2 rear resonators with 14" Magnaflow. 2020 1500 CC 5.7.
Sounds great! Thanks for posting.
What are your thoughts? Are you happy with it? Any drone? How's the volume? Other thoughts...
Night and day compared to just having the magnaflow. Got rid of the “exhaust leak” sound after removing the resonators. No issue with drone, sound awesome when hitting the gas and quiet as stock when cruising.
I have the magnaflow 14 inch and it sounds the same with resonators as I can hear in the video. Is the resonator delete that different in person? Can you post a video from in cab and with someone hitting the gas?
I deleted the resonators with the same muffler. It definitely sounds better and loses much of the drone.
sounds good, i have that exhaust leak sound too and it sucks lol i may look at doing this, how much louder do you think the truck is now then from before?
Old thread but hopefully you guys are still around. So is it significantly louder after res delete? Or just basically eliminates the fluffy air sound? I have the Mag 14239 14” muffler and its great but it sounds so much better the first minute or so of driving then after that just kind of fades a bit. Its like its so much deeper sounding when cold. Wondering if I should delete the reses? As the poster above mentioned, do you have the resonator up front?
Just do it. It’ll make it a little louder. Not much. You’ll like it
