Ellisstrong
Naw i have a white led in there. I replaced them prior to getting it smoked.did you put a red led in the 3rd brake light to help the red color come thru the smoked tint ...
Looks good, i have the front Bilsteins on order. Did you switch out the UCAs? And is there still any rake?Bilstein 5100s on setting #6
Yokohama geolander MT 275/65/20View attachment 51521
	Man that setup looks great. Do you have the factory ORP or no? And why the difference in wheels spacers from front to rear?
. 3.21's or 3.92's...If 3.21, I curious how the truck feels with that size Ridge Grappler...since it's a 70+ lb. tire. I can't decide on tires as I fear getting ones that are too large or heavy. Truck looks great!Details in are in my signature.....
I have 3.92 gears so I notice a very slight, if any any difference as far as acceleration is concerned. Where I can feel a difference is when I hit a pothole or larger bump, that's when I know I have a heavy ridged 10 ply tire on there. Guys are running 35X12.5 grapplers all day long and in some cases with a heavier rim than stock rims. I would'nt worry about the tire weight at all even with 3.21 gears, that's why we got these hemi engines right??3.21's or 3.92's...If 3.21, I curious how the truck feels with that size Ridge Grappler...since it's a 70+ lb. tire. I can't decide on tires as I fear getting ones that are too large or heavy. Truck looks great!
I personally do not have that lift but there are several people on here that run that lift and seem happy with it, I'm sure they will chime in. I think there may even be some threads specifically about the readylift 3.5. Good luck, congrats on the new truck.Hey fellas..looking to put this on my 2WD laramie. Says it will fit both drivetrains but just want to be sure. Just brought the truck home yesterday so starting to do some research. Does anyone currently run this lift or know anyone that does?
Sounds good brother thanks for the helpI personally do not have that lift but there are several people on here that run that lift and seem happy with it, I'm sure they will chime in. I think there may even be some threads specifically about the readylift 3.5. Good luck, congrats on the new truck.
Just installed Motofab 2.5" leveling kit with 295/60r20 Faulken Wildpeak AT3Ws. I love the look. Ride isn't bad, but not as smooth as the stock Bridgestone H/Ls (although I didn't like their wet performance). Need to play with air pressure a bit ... currently running 40ish. I am getting a rub at full turn for tight u-turns which bums me out a bit since others have said they're running the same setup (maybe not Faulkens) with no rubbing.
Edit: Rub is gone. Fully screwing down the OEM mud flaps does wonders.
		2019 North Edition
3.5” Ready Lift
Rear /Air Lift Performance Helper Bags
20” Hostile Sprockets on 33” MTs
Rough Country 6” LED Light Bar kit
Got a side shot? Want to see the wheels!
