*OFFICIAL Rough Country 3.5 // ReadyLift 3.5 thread.
Bee7_ivan
Can everyone that are running these kits
Post an image below?
*Rough country 3.5 or ReadyLift 3.5
*Tire brand
*Tire size
*Wheel size
Thanks for tagging along!!
Looking back I wish I would have gone with the same tires but in the 35/12.5r22 with no offset. That’s the recommended tire size and I think it would have fit fine with 0 offset. Not much difference in size, but a bit more aggressive.
readylift 3.5 " with nitto trail grapplers 35x11.50 with 20" fuel titan wheels 20x10 with -18 mm offset. The tires did scrub at full lock but i heated the plastic wheel liners up and pushed them away from the tires and they dont scrub. Im overall happy with the looks and the quality of the lift.
Rough country details in signature
Nice lift/tires!
I have the Ready Lift 3.5, with Terra Grappler G2 285/55r22. View attachment 46948
I am 95% sure I am getting the Trail Grapplers because I found a great deal. They are MT which makes me a little nervous ... I would have done the Terra's too but these were at a price I couldn't pass up. I am the second owner and the original owner has a lift kit (or levelling kit) on the front. Trying to figure out what it is but I am removing it in favor of the Eibach Pro set when its ready in January. I have the same color and 22" rims as you, almost exact same truck with the Laramie L2 package and black appearance so I assume mine will look very similar. Do you know by chance as it sits what the distance is from center hub on the front to fender lip?
Just picked up a 2020 ram1500 bighorn north edition, got the 3.5” readylift sst ordered with 35x12.5r20. I do have the off-road package so I’m curious what the truck will look like without the strut preload spacer. Thanks!
Any pics of the truck with the 3.5 Readylift installed ?
Wow only 10 or so trucks on here with this lift? That’s surprising. I thought I’d see a lot more. I’m sure there are but I guess not posted here.
I just picked up a new 2020 Laramie a week ago and the ReadyLIFT 3.5” kits arrives on Wed. Hope to install this weekend or next week. I’ll post up pics when I get it done.
I have the ORP as well and would LOVE to see the outcome without the pre-load spacer installed. I would never run a pre-load spacer, so I'm wondering if it would drastically change the overall lift height that much. I like a little rake in my trucks anyway, post pics after your install @NorthRam1500
Does there seem to be a lift height difference in between the ready lift 3.5 and the rough country 3.5 kit? I’m talking about actual height achieved after the lift?
Little before and after, did not install the preload spacer so there’s a bit of rake which I don’t mind. Once spring arrives I’ll put my summer tires on.
3.5” ReadyLift SST with bilstein adjustable ride height front shocks set at position 5 in lieu of RL 2” preload coil spacer, and RL 1.5” top hat spacers on 295/65/20 Nitto Ridge Grapplers and stock 20” wheels.
Do you have any more pics of the truck, I literally have the same truck and want to do the same, thanks. Truck looks great!
Here ya go...
