PorBoy
You’re looking at about $160.00 for that.
Where did you buy your suction cup from? link?Changed my chrome mirror caps from chrome to bodycolor today.
Used a different kind of suction cup, the ones they use to lift glass. Works even better than the dent puller suction cup because this one is more solid.
I heated up the mirror for about 5 minutes with the heat gun. I didn't even had to pull that hard.
No broken mirrors and both caps changed witin 30 minutes.
What process did you use to remove the adhesive residue when you removed your “RAM” emblems? I’m finding it very stubborn.
I miraculously got it back together, not without breaking half the tabs and what not. Took me 2 hours to figure the damn thing out... the motor housing easily snaps out of the mirror housing. There's a T10 Torx screw in the middle that also holds the motor housing to the mirror housing, and also acts in part to hold the halves of the motor together. After removing the motor entirely, I stared at it for awhile trying to see why it wouldn't go together... it's hard to explain. Basically the half with the actual motors has a notched ring all the way around, and this ring snaps inside of the other half. Not without a ton of prying and pressing force though. I can't believe it came apart, and I REALLY can't believe I got it back together. Was about to throw it across the driveway and go to the dealer this week to hopefully get a new one, but I couldn't find the part online and the numbers on the motor housing didn't lead to anything, so I figured I needed to fix it myself.
This was the 4th mirror I did. The first 3 went smooth as butter. I should have known something was up when this mirror didn't come apart as easily/quickly, yet I kept pulling... probably needed to use more heat, but maybe it was unavoidable. I have used the suction cup tool... wouldn't try it with anything else.
Found out you can't just order the motor. Have to replace the ENTIRE mirror assembly, not just the mirror motor/actuator. $302 from Bam auto parts. Ouch.Same sh%$ happened to me with the motor splitting in half on the passenger side. No luck getting it back together either. Does anyone know the part number for the mirror actuator/motor? Drivers side took about two minutes after heating and the mirror released from the entire motor, no issues.
I finally took on this project without breaking any mirrors. I purchased a decent tile/glass suction tool similar to simbad001 from Home Depot (https://www.homedepot.com/p/QEP-4-7...andling-Large-Tile-and-Glass-75000Q/100119050). It is pretty warm today in Houston (around 85). I drove to Home Depot, left the truck in the driveway with the sun on it for 20 mins, hit each mirror with a hair dryer for a minute or 2, and popped the mirrors off fairly easily. The mirrors do still require some force to remove, to the point that the electrical connections got disconnected in the process. Not damaged, just didn't even have to make the choice whether to disconnect or not. The only issue I had was I initially removed the wrong T20 screw and couldn't figure out why the mirror cover wouldn't come free. The one I removed was a machine screw (metric threads) and if I was paying attention, it would have occurred to me that wasn't correct. The correct T20 is a screw for plastic, with threads that look more like a wood screw. Anyway even with the temporary delay, the whole process took about 30 minutes.
I went the different route than most in this thread, I removed black plastic covers from my Crystal Granite Lone Star edition and added chrome mirror covers. If anyone in the Houston area wants the black plastic covers, message me and you can come pick them up. I won't ship, so don't ask. I did apply Cerocoat to all of the plastic on my truck so they do have a bit of shine to them.
Sounds like you’re prepared to take the plunge. I ordered the suction cup about 4 months ago and finally got the courage up to order the covers and give it a go and as I posted above it took all of 10 minutes. I didn’t turn the mirrors I actually centered them and also heated only on the actual mirror and around the edges of it and gave a couple small pulls and it popped right out. Make sure you have a flat head screwdriver or something to free up the clips to get the cover off. Good luck and post your results here.I ordered a couple of mirror covers to match the color of my Limited, I can deal with the chrome everywhere else on the truck but the mirrors are just too much.
After reading this entire thread (everyones experienes and reviews have been very informative and super helpful by the way) I just want to make sure I've got the procedure to switch these out (hopefully without breaking the mirrors) down to a science.
I'm going to park my truck in our warehouse at work and let it sit for an hour or two, it's heated which should help as it's still not that warm here in Nova Scotia.
1. Use the mirror switch on the drivers door to turn both mirrors away from the truck as far as they will go.
2. Use a heat gun all over the mirror for a few minutes (cover, glass etc.) to get it good and warm.
3. Place the suction cup as close to the center of the mirror as possible, I already have a red suction cup identical to the one Sambad001 used so that's what I'm going to use
4. Brace the mirror with your free hand and pull straight back on the suction cup with the other hand to remove the mirror
5. Pop the cover off (4 clips, 1 screw)
6. Put the new cover on (seat the clips, put screw back)
7. Make sure all wires are reattached to the same spot they come off of (hoping not to disconnect them), put mirror back on
8. Test Mirror Functions to make sure everything is still working
Please feel free to chime in if I left anything out.
Thanks!
Glad you got it done with no broken mirrors, truck looks great with the color matched covers.Installed! Everything went well except the sticky piece that holds the sensor for the blindspot detection function came off. I put the heat gun to it and it rebonded nicely. Heating just the mirrors up with a heat gun really helps in removing them.
Looks like you can find it on Amazon too for 51 cents more, plus it had free next day shipping for me!
Performance Tool W1028 Suction Cup Dent Puller https://www.amazon.com/dp/B000GKD6X2/
This unit is an absolute piece of crap, it just doesnt glue to the mirror, i'm trying since half an hour now
