- Feb 24, 2018
- Solutions
- 1
- Location
- Central Pennsylvania
You probably already know this if you’ve been reading this thread but the dry tongue weights listed by the trailer manufacturer can be very optimistic. Many come off the line heavier than the advertised weight and most manufacturers don’t include filled propane tanks and batteries, not sure about Lance. Then you’ll need to add ~80 pounds for a good weight distribution hitch and figure 10-15% of the weight of all the gear you put into the trailer.Most of the dry hitch weights of the trailers I'm considering ( Lance 24 series) are between 550 and 665 lbs.
Correct. There are tire calculators that will give you the exact same tire size.Thanks @devildodge . So as long as the 275/55R20XL tire & wheel combination is the same diameter (~31") that I have on the 22" setup it should play out fine?
Should have said Diesel....Lol have to get used to saying that.![]()
Last Saturday picked this baby up and drove it home 650 miles on one tank of gas. So far love it..,,
Weighed the spare tire today and it was only 50 lbs dead on. Took one of the 285/45R22XL tires off and weighed it and it was 82 lbs. Both weighed less than I'd thought they'd be. At best I could get set of new tires and wheels @ 62 lbs from TireRack and that's a pricey way ($2k+) to only gain 80 lbs back so I'm not going to do that. Moving the truck spare into the trailer and not taking the tonneau and rambox divider gives me back 100 lbs easy. So I'm going to be sitting at 1161 when towing. I wish there was something else I could think of that would give me back a little bit more. It's a damn shame that Ram is setting the GVWR @ 7100 when those eco diesels get an extra 100 lbs magically (note that the GAWR's didn't change) at 7200.Keep us posted. We haven't been helping much with this lately. I find it fun and interesting getting a setup dialed in.
Hi all. I'm a new member and this is my first post.
New truck owner here and I've discovered this forum and thread recently. I picked up a 2020 Limited 1500 with the "Black Appearance" package which includes the 22" gloss black wheels and 285/45R22XL Goodyear Eagle Touring . My options include: Bed Utility, Limited Level 1 pkg, Pano sun roof, 3.92, anit-spin, 5.7 hemi + eTorque, Rambox w/ cargo divider, brake controller, factory Tri–Fold Tonneau Cover (came with appearance pkg) and that beefed up multi-function tailgate and I'm at a depressing 1061 lbs on the yellow loading sticker.
I bought this with the intention for towing a ~6,000 travel trailer that I'm still in the market for buying. Most of the dry hitch weights of the trailers I'm considering ( Lance 24 series) are between 550 and 665 lbs. With just my wife and me and nothing else we're pushing that top 7100 GVWR limit.
If I remove the tonneau and the rambox divider and put them in the back of the trailer I gain back nearly 50 lbs. Moving the truck spare tire to the trailer gives me back another 90 lbs. Now I'm considering at buying a set of lighter wheels/tires. I see on Tire Rack They have a 20"x9" Granite Alloy that's only 25lbs. Looking at most the the 275/55R20 all seasons that fit that tire they are also a at least 5 lbs lighter than the 22" Eagles I have now and have a higher load index to boot (2,892 lbs over the 2,601 lbs on the 22"'s). I haven't weighed the OEM 22x9 wheels yet, but I'm guessing there at least 45 lbs. I can see gaining back another 90 lbs of payload by switching over to the new set of 20"s
Would there be any issues with switching out the 22's for 20's? I'm looking to give me some headroom for keeping it legal and safe with a trailer that conforms.
I am actually a female but that's okay. I'll still take it.A huge Thank You goes out to @Dawn
Thanks to his effort, we now have a very accurate payload and towing calculator.
It is such a shame RAM screwed so many with their unreliable, inaccurate calculator, but was able to fix it that quick.
Through some research, not only has it been fixed for new trucks, but also for older trucks as well.
So, hopefully now we can get some more useful information from the configurator and some more pleasant experiences.
So sorry. Your effort is greatly appreciated. Guess I need to pay closer attention.I am actually a female but that's okay. I'll still take it.
That's okay. Because of this experience, I now have a much better understanding about towing and payload. Why FCA and the dealership tried to tell me that my 2500 could handle a 16000 lb fifth wheel still blows my mind. Maybe it could. Who knows. But there's a big difference between capable and legal and I for one love my family, $80k truck and my low car insurance rates and would rather not play Russian roulette.So sorry. Your effort is greatly appreciated. Guess I need to pay closer attention.
You can not imagine how much this makes our conversations about the issue easier. We won't have to spend 4 posts explaining that 1840 and 11500 is not the payload and towing.
Thanks again.
Thanks for the reality check Zeronet. Wife and I found one of the last of the Grand Design Imagine 2150RB's (phasing them out for 2020) and it not only fits our weight budget but we actually love the layout too. I'm sure with LP, battery and loaded up passthrough well be above the 427 lbs dry but given that it's an inherent 8% GTW to UVW, I can't really see it going above 600 lbs if we weight manage it right. Not to mention that with WD engaged, a little bit of that GTW is going back on the trailer.You probably already know this if you’ve been reading this thread but the dry tongue weights listed by the trailer manufacturer can be very optimistic. Many come off the line heavier than the advertised weight and most manufacturers don’t include filled propane tanks and batteries, not sure about Lance. Then you’ll need to add ~80 pounds for a good weight distribution hitch and figure 10-15% of the weight of all the gear you put into the trailer.
My camper, for example, had a dry tongue weight of 658 (see camper specs in my signature). Ready for camping it’s around 840 (sometimes more). Then add 80 for my weight distribution hitch and I’m at 920. That’s after relocating batteries and a concerted effort to keep the tongue weight down.
Then we usually carry a generator and other misc gear in the truck, probably another 200. Add in my wife and I and the truck crosses the scales at 7020 when hooked to the trailer with weight distribution engaged. Payload sticker on the truck is 1479. The weight adds up quick. Truck handles the weight well considering it’s close to max.
Not trying to rain on your parade, just sharing my experience. Your results may be different. My guess is that it will be tough to stay within GVWR given your payload and the trailers you’re considering.
