Bighorned
anyone have wind noise from drivers side door up top by the corner. I can pull in with my hand and it goes away but if I lean just a tad on the door it has some serious wind noise.
			Got a picture yet?I got mine fixed I attached some foam Nader the weather sealing and it worked !
I will take a picture later.
It doesn’t look pretty but it works first try I might need to make it look pretty![]()
Yes I know exactly what you are referring to. I even hear a change in cabin as if suddenly the wind causes something to come open and air rushes inside.I have the same noise. It’s coming from the ac cabin air recirculater . When I’m at highway speed it starts , only when the ac recirculating is on . When I turn it off and get outside air the noise goes away. There must be a seal that isn’t sealing off the outside air completely.
Mine is at the top of the drivers side window. Starts at about 68 MPH and peaks about 74 MPH irregardless of wind conditions . I have noticed that it diminishes when I pull in on the drivers door handle. I wonder if adjusting the door latch would fix this ?
Hello guys I just too delivery of my 2019 limited and today I drove it home about 300miles away from the dealer. Well the wind howling was so loud I could hear it over the radio and the road noise. It was a bit disappointing. Anything over 70mph and the noise was more than noticeable it was annoying
I have some wind noise also. Seems like its back seat passenger side. Much worse in a cross wind than head or tail wind. Will need to sit in the back seat while someone else is driving to locate source.
Would like to know more about the location of the weather stripping that helped/worked...
Thats where mine is also
Yours sounds like what they describe as the missing bed seal. There is a TSB for it if thats the issue. I have attached the TSB.I have some wind noise also. Seems like its back seat passenger side. Much worse in a cross wind than head or tail wind. Will need to sit in the back seat while someone else is driving to locate source.
I have the same thing. I'm curious too if they can adjust something.Mine is at the top of the drivers side window. Starts at about 68 MPH and peaks about 74 MPH irregardless of wind conditions . I have noticed that it diminishes when I pull in on the drivers door handle. I wonder if adjusting the door latch would fix this ?
I checked mine and I have the seal missing !Yours sounds like what they describe as the missing bed seal. There is a TSB for it if thats the issue. I have attached the TSB.
No problem, check and see if the seal is there, it's to most common problem when people are hearing noise from the rear passenger door. I really like this billet silver, I think it looks the best on over cast days without direct sunlight.Billet15004x4, Thanks for the link. My noise sounds like a jet engine from a long ways away. BTW. My truck is a billet15004x4 also!
Take a copy of the TSB into the dealership with you can they should get you fixed up.I checked mine and I have the seal missing !
Did you do this? Is there nay documentation or case information you can share?Just an FYI for anyone - The whistle/tea kettle noise can be handled through lemon successfully.
Please explain further.......I got mine fixed I attached some foam Nader the weather sealing and it worked !
PM sentHi all,
I regret to hear of the shared concern that you are experiencing. If you move forward with addressing this with your dealers, please be sure to let us know via private message. I would like to have cases created to have this documented, as well as get you connected with a specialist for extra support while working with your dealers.
Mark
RamCares
Where exactly did you do this? Ever get any pics?I got mine fixed I attached some foam Nader the weather sealing and it worked !
