installed a B2 fab. straight pipe. left stock resonators and it sounds great. Only thing is the weep holes in the resonators. There are 2 in each I plugged with Copper rtv. worked perfect. No more leak noise.
Finally finished Train Horn, Rock Lights, USB ports in bed, cigarette charger in bed, air pressure valve and air line in bed.
MX 4 was installed a while back and local shop did a good job as sealing the tail gate area for leaks. Had the bed sprayed last week and had to re-do the seals at the tail gate area. Went a little further then the local shop did with the seals this time. No leakage at the tail gate with the MX4. After the pictures were taken I re-installed the normal gasket along the bottom of the tailgate to keep the dust
out.
View attachment 40834View attachment 40835
Does anyone know why they have a hole in the bed wall near the anchor? It seems like all of the trucks I have had, have a hole in the bed walls. Usually just cover them up,
What gaskets did you use to fill in the gaps on the tailgate and top of bed area. Having a Retrax put on and want to do the same. Thanks
I didn’t have any gaps at all with the Retrax. Completely sealed shut.
Can anyone tell me what this space is used for or what it can be used for? Is there another great option I don’t know about yet?
Wow! You're one of the rare few I've seen with the OEM aux switch package one of the other photos on the forum is here and there's a blank there as well.. huh..
Wanted to add the addition power and lights to it. Next want to put an additional 115 plug like what’s in the ram boxes as well since I do t have Ram boxes will Mount my own on opposite side of bed.
Did you add a air compressor or tap into the air suspension?
That's because it's a HD model truck, not a Ram 1500. I have a HD 2019 Limited 3500 as well as the 2019 Ram 1500 Limited, and the HD has that type of system (AUX extra buttons).
Installed a set of Ram OEM Off Road Flares on a 2020 Ram Sport.
Part Number : 82215284AB
Pretty simple bolt on install. I like that these flares don't look too bulky and that the matte black matches the rest of the truck's matte finishes.20191204_215920.jpg20191204_230603.jpg20191204_230625.jpg
Did you by chance record the steps you followed for the cigarette lighter and usb installs in the bed. I used to have a Tacoma and loved having the outlet back there. Would like to add someday to the Ram.
I installed a set of tecoom mud flaps for my laramie with fender flares. The mud flaps fit very well and were easy to install. At only $49 on amazon thats a pretty good value. Free returns if you held them up and didnt like them makes for safer buying experience.
Nice tip! I looked and saw them for $75 on Amazon (link); the $49 ones were for 'w/o fender flares' - unless there was a sale?
