Nope looks like you have it right to me. Spools off the top when powering the winch in.
Need to know if they go to frame or just in running board mounts as a caution I went on my hands and knees to look at the factory option rock sliders on a coworkers Colorado ZR2 and they go to the running board mounts in the unibody so big Fail there.Those rock sliders though!
My ultimate goal is to build a similar overland vehicle.
They get enough free stuff already, send us some free stuffYou guys have to send a mount over to the TFL Trucks crew for their Rebel project truck.
 Here's my raffle entry.
  Here's my raffle entry. qqq
qqqQuick question. Switch with lights has 3 wires, Warn aux ports use only 2. Can I just ditch the dedicated ground on the switch and run two wires? Or do I need to body ground that?
 Should also say that I am super happy with the product, as well as the instructions and overall customer service. Great job guys! Very much appreciate the service throughout.
After being quoted...lol....$1700 from 4wheelparts for the install. Was a no brainer to DIY it. I ended up buying a new cordless impact, a bunch of other new tools, a new tool cart, all my recovery gear and a bunch of beeeeer and still saved over $1000. (actually, lost count cause i've just been buying things and using the savings to justify everything)
Couldn't be happier.
 And part because I had to relocate my electronic air horn, because it was attached to the sheet metal behind the bumper that gets cut out to clear the winch.
  And part because I had to relocate my electronic air horn, because it was attached to the sheet metal behind the bumper that gets cut out to clear the winch.Looking good!! 1 thing to suggest. Replace the machine screws for the clutch bracket. With stainless.
