1Zach1
If it turns out to be a real world 1,000mile truck like RAM has claimed, there isn't much more of a selling point I need. I have loved the EcoDiesel in my Grand Cherokee so I look forward to seeing how the re-test goes.
I'm holding out for the Eco, but it would take almost 75k miles to break even at 33 mpg vs 16mpg and the 4k upcharge on the diesel to break even. That does not add in the extra cost of owning a diesel.If they run it again and get 33+ its going to be a game changer...might have to jump ship...16 mpg with a 34 mile one way commute is killing me
Let’s say you paid 50k for a hemi truck, and 55k for a ecodiesel. Drive for a few years, trade it in. Hemi truck is worth 25k. Ecodiesel is worth 28k. What’s the real difference? 2k dollars.
No one ever talks about how the truck will be worth more at resale. It’s not like you just pay for the diesel option without any benefit, it makes the truck more valuable.
You’re correct, but what I’m saying is you get most of the money spent back. It’s not like saying you spend 4-5k on the diesel and now both trucks are worth the Same value in the end, 25k in this case. If that were true, then yes you would have to make up the full difference in fuel savings alone. But it’s not the case. You spent more on the truck, it’s worth more later as you said.
As mentioned, there is a flaw in your thinking. You still lost $2000 when you traded your diesel in. You spent more money for the same truck. You need to keep it long enough before the gas savings kick in, and at that point where gas is saving you money, you're outside the warranty with a very expensive-to-fix engine.
1: Because they canPardon my ignorance, but why is an oil change on a diesel more expensive?
Why is diesel repair more expensive than a gas engine? I realize that the previous diesel motor had some issues. Assuming that the point of those catastrophic failures have been corrected, why wouldn’t the motor go a couple hundred thousand miles like a gasser could? Why would repair/parts cost more? Is it that the cost of parts is higher due to a generally low production of the motor when compared to the 5.7 Hemi?
The Hemi takes 7-8, the ED takes 11.In general, a gas engine takes 5-6qts. A diesel takes 10-20 depending on size and what have you. This is a loose explanation, but the diesel has 2-3 times as much oil capacity.
Watching the videos of the interviews of FCA's chief engineer for the eco-diesel, he says you will fill up the DEF tank about as often as you get oil changes. So it doesn't seem like you'll need to get DEF every time you fill up the diesel tank.Repairs also cost more because diesels have to run at much higher compression than gas and that makes many of the parts more expensive. Look at the cost of fuel injectors for a gas engine vs diesel. The fact that there are a lot fewer diesel mechanics, especially at car dealerships, means that they can charge a premium for their work.
Plus when you figure in the fact that diesel now costs more per gallon than gas and the extra cost of DEF and the inconvenience of finding diesel stations and adding DEF there are even more factors against diesel for a light duty truck.
.Flawed thoughts my friend. Of course a more expensive truck is going to have a higher resale because it was a more expensive truckYour numbers aren't "real" but assumptions so I'll play along. If I pay $50K for a HEMI and $55K for a DIESEL, then I spent $5K more for the DIESEL. If after several years, the $50K truck is worth $25K, as you stated, then I lost $25K on my investment. If the DIESEL is worth $28K, then I lost $27K...in the end, the real difference may very well be ZERO (using your math it shows $2K but we have no idea what's "real"). Who says that the diesel trucks will hold their value any better than the proven HEMI? Just sayin.....
