Neurobit
RAM Sorcerer
If you hand wash, they can last a while. Two years or more. If you get a scratch, you can always touch up.I did. I failed to mention that the first two tires were a disaster. I was holding the cans too far away and wasn't wetting it enough. I ended up with a tremendous amount of texture. I had to remove the dip on those two tires and start over from scratch which cost me a lot of labor and time. Fortunately, time, patience, practice, and no less than a dozen you tube videos later, I was able to get results that I was pleased with. I used approx. 1 can of black per wheel and 2 cans of gloss enhancer. In all, it was 1 base coat, 4 wet coats, and 3 gloss coats. Now to be careful in taking care of them. Not sure how durable they are.
I’ve had tires replaced and the rim edge stayed intact, so pretty durable.
 reaching over them. Thanks for the suggestion.
