Diamondback
Midwest
Got my Ceramic Pro Coating done (Silver Package)! Looks great...I hope it lasts as advertised!
Looks great!
Mine came with the Platinum version .. I like it .. now if they will just take care of the 2 inches of water I get inside the cab when it rains LOL
reigninslayer
Was looking for a storage solution for the bed so things wouldn’t slide around. Came across these bins in Home Depot. Bins cost $11 each and the ratcheting bar was about $20.
Bins
Bar
These bins work great with the bar. They even have pre-drilled holes near the top of each bin which made it easy to secure them to the bar with black zip ties. There is even a notch above each pre-drilled hole that keeps the zip tie from sliding back and forth. The left and right sides of the bins fit snug under the cargo bed rails as previously mentioned.
TNSmokee
Collierville, TN
How does it sound and any drone issues? Do you have a video clip?
Thanks
I don't have one but it sounds exactly like the others. That is how I made my decision. I have a 2013 F-150 with a MagnaFlow and my more importantly my 2017 GMC had a MagnaFlow. The GMC went into v4 mode too so I was use to the helicopter sound. The Ram is really no different there when it comes to hearing a difference when it switches into 4cyl mode. It doesn't bother me enough to not enjoy the rest of it. I've had loud and obnoxious and I've had just barely noticeable. This is perfect for me. Startup is great and quiet downs pretty quickly. WOT is perfect but to me and this is to me the best is second and third climbing an incline. IF the v4 helicopter is too much then run the gear down to -8. On my GMC I had to run it in 7th gear up to the point I programmed it to turn off v4 mode. This one just isn't that bad to me.
TNSmokee
Collierville, TN
Picked her up this morning after a week in the shop. I had a water leak. One service writer said sharkfin and one said 3rd brake light. Ended up being the drain tube grommet from the rear cabin had separated and causing the leak. Hopefully that's it. I attached the picture that my service writer sent me in case someone else has an issue.
rrbhokies
Biggest project time-wise was plasti-dipping my stock Laramie 20" wheels black. I hat the stock rims, but they look better black at least until I can afford a new set of wheels. I also installed a Hellwig Sway Bar, and a Pedal Commander. Finished the weekend off with a few trim items. Gotta say, she's coming coming along............... perfection takes time!
Neurobit
RAM Sorcerer
Texas
Awesome job. Congrats.
19BlkRam
You ever get pulled over with tint that dark? Im in davie an thought about doing it but im not sure.
Nope, I do have the sunroof on this truck though so it allows a bit more light to show up on the truck. Ive tinted all my vehicles this way and have never had any issues but then again I don't call much attention to myself driving (Speeding, Smoking etc...)
Take a picture before doing the tints of your truck for your records ;);)
worst case scenario you give the guy at the tint counter $20 bucks for a receipt that you had the window tint removed and you have photo evidence that the car no longer has tints applied..
Ive never done this before but If I had to this is what I would do ;)
Helmetface
Flush cut those ties before someone loses an eye!
RAM Patriot
Clayton GA
Good Job!!! (y)
When I used plasti-dip on my fender flares, I kept getting orange peel..
Did you do this with cans?
RAM Patriot
Clayton GA
Thanks. It's a Rubbermaid that I have customized by adding the metal hooks to hang the large brushes, and also drilled holes behind the handle to hang the brush holder.
These carts are awesome. Not the cheapest, but they will last a lifetime.
Where did you get that brush set?
I suppose you use those for the tight spots in the wheels... :geek:
rrbhokies
Good Job!!! (y)
I did. I failed to mention that the first two tires were a disaster. I was holding the cans too far away and wasn't wetting it enough. I ended up with a tremendous amount of texture. I had to remove the dip on those two tires and start over from scratch which cost me a lot of labor and time. Fortunately, time, patience, practice, and no less than a dozen you tube videos later, I was able to get results that I was pleased with. I used approx. 1 can of black per wheel and 2 cans of gloss enhancer. In all, it was 1 base coat, 4 wet coats, and 3 gloss coats. Now to be careful in taking care of them. Not sure how durable they are.
RAM Patriot
Clayton GA
You did a Great Job... You must be patient...
I heard that it takes about a month for them to cure and harden up. This hot heat should help you with your cause... ;)
