Leif_Ram2019
Thanks for posting. I am also eagerly awaiting this cap.
I called ARE yesterday to see if there are any updates because I really want the CX Evolve.
The lady was pretty tight lipped and said they are still redeveloping that topper. I couldn’t even get her to give a 3 month, 6 month or even 1 year or longer projection on availability.
Just too bad, I would shelled the money for one of those things.
Mine is a Leer 100R. In hindsight, I wish I would have ordered the 100XR as the back door seals better. The lines would be the same on either.I just purchased a white big horn crew cab sport and looking for a cap. Not many companies with 2019 models out yet that I've seen. Hoping for recommendations that look clean, fit body lines well, and seal well. Looking for more of a sporty look than utility and don't want a high roof.
Thanks
. Son of a... really? I ran across this video today.
Personally, I think the cap is mounted to far to the rear of the truck. My ARE Z cap mounts with the cap corner and the truck bed corner about flush. If that doesn't fix it, then he does have a gripe. I would point out however, the whole rear door glass and if they want in, it's pretty simple to just smash it.That looks like the "strike latch" just needs to be adjusted.
Personally, I would never drive away with a product that did that.
Please post pics when installed.My REVO is set to be installed this Tuesday. Pretty much 8 months after i ordered it. I hope like hell there is no QC issues and the color matches.
Why deal with a company that does not produce a product. Went thru that last fall with wanting a Z series.This video is not making me feel good about this topper. I ordered an Evolve, but was told I am months out and that they aren’t making the Evolves for Ram yet. I dunno, I’m now contemplating cancelling my order.
Turned to LEER. Ordered a QX and 3 weeks later its on my truck. DONE
I’ve had enough of ARE. Both my dealer and ARE won’t give me a straight answer on when they will even book my order. It seems like there have been mounting issues with the Evolve/Revo for too long and this video was what put me over the edge, even if they fixed the issue....what’s next? I just received a quote for a Leer 100xr with vented windoors, flipdown slider front window, carpeted ceiling, and auto dome light for $2600, tax and install included. I wish it was less expensive, but I’m going to pull the trigger. No more waiting around.
do you have a pic of the back glass from the outside ?Had the REVO installed today. It seems like a nice topper except for the fitment of that damn back window!
To get it to seal against the tail gate, the strike plates had to be adjusted so tight that even if I slammed the window it wouldn't latch. I would have to put some force into pushing on each corner to get them to click. If I set it so that it closes without having to press then there is 1/4" gap in areas on the bottom edge.
It seems like there is something out of alignment or binding that causes the one side to not close without extra force. I've adjusted the latches, the latch plates and window hinges trying to figure out what the hell is going on.
I already did way to much ****ing around after paying $2700 for it. I figured I could just adjust the hinges better at home and I did to some extent but now I have to fix that gap issue.
O and the video I posted earlier, yeah pretty easy to get into it when locked. So whats the point of having the lock mechanism tied to the key fob if the lock can be bypassed.
I have the choice of slam shutting and pressing the door close to not have the gap or adjusting it like it is now and being able to shut it firmly but have a gap.
The simple fix is finding a bigger window gasket for bottom of the window. I don't know why they put such a small one on in the first place.
Still doesn't fix the security issue.
O and gotta love the cheap taped on LED light...
Going to work with the company i bought it from and see what they have to say or can do. If anything I will try to return it and go get a Leer.
