Where’d you find them? Couple places I’ve checked they’re around $130 for the pair.
Bought from the dealer
Got my Ceramic Pro Coating done (Silver Package)! Looks great...I hope it lasts as advertised!
Wouldn't you want to put those mirror caps on before you have the PPF/ceramic done?
Was looking for a storage solution for the bed so things wouldn’t slide around. Came across these bins in Home Depot. Bins cost $11 each and the ratcheting bar was about $20.
Bins
Husky 55 Gallon Multipurpose Stackable Space Saving Heavy Duty Storage Bin in Black 232387 - The Home Depot
Store your household maintenance supplies and power tools to sporting goods, shoes and boots with the selection of this Husky Stackable Storage Bin in Black.www.homedepot.com
Bar
	what brand are these?View attachment 33597
Before
After
Paid $52.48/side and $1/each for the extra screws.
Looks way better!
How does it sound and any drone issues? Do you have a video clip?
Thanks
I don't have one but it sounds exactly like the others. That is how I made my decision. I have a 2013 F-150 with a MagnaFlow and my more importantly my 2017 GMC had a MagnaFlow. The GMC went into v4 mode too so I was use to the helicopter sound. The Ram is really no different there when it comes to hearing a difference when it switches into 4cyl mode. It doesn't bother me enough to not enjoy the rest of it. I've had loud and obnoxious and I've had just barely noticeable. This is perfect for me. Startup is great and quiet downs pretty quickly. WOT is perfect but to me and this is to me the best is second and third climbing an incline. IF the v4 helicopter is too much then run the gear down to -8. On my GMC I had to run it in 7th gear up to the point I programmed it to turn off v4 mode. This one just isn't that bad to me.
Awesome job. Congrats.Biggest project time-wise was plasti-dipping my stock Laramie 20" wheels black. I hat the stock rims, but they look better black at least until I can afford a new set of wheels. I also installed a Hellwig Sway Bar, and a Pedal Commander. Finished the weekend off with a few trim items. Gotta say, she's coming coming along............... perfection takes time!
You ever get pulled over with tint that dark? Im in davie an thought about doing it but im not sure.
These bins work great with the bar. They even have pre-drilled holes near the top of each bin which made it easy to secure them to the bar with black zip ties. There is even a notch above each pre-drilled hole that keeps the zip tie from sliding back and forth. The left and right sides of the bins fit snug under the cargo bed rails as previously mentioned.![]()
Good Job!!!Biggest project time-wise was plasti-dipping my stock Laramie 20" wheels black. I hat the stock rims, but they look better black at least until I can afford a new set of wheels. I also installed a Hellwig Sway Bar, and a Pedal Commander. Finished the weekend off with a few trim items. Gotta say, she's coming coming along............... perfection takes time!
Where did you get that brush set?Thanks. It's a Rubbermaid that I have customized by adding the metal hooks to hang the large brushes, and also drilled holes behind the handle to hang the brush holder.
These carts are awesome. Not the cheapest, but they will last a lifetime.
I did. I failed to mention that the first two tires were a disaster. I was holding the cans too far away and wasn't wetting it enough. I ended up with a tremendous amount of texture. I had to remove the dip on those two tires and start over from scratch which cost me a lot of labor and time. Fortunately, time, patience, practice, and no less than a dozen you tube videos later, I was able to get results that I was pleased with. I used approx. 1 can of black per wheel and 2 cans of gloss enhancer. In all, it was 1 base coat, 4 wet coats, and 3 gloss coats. Now to be careful in taking care of them. Not sure how durable they are.Good Job!!!
When I used plasti-dip on my fender flares, I kept getting orange peel..
Did you do this with cans?
These are the factory liners. Picked up at my local dealer for $52 per sidewhat brand are these?
You did a Great Job... You must be patient...I did. I failed to mention that the first two tires were a disaster. I was holding the cans too far away and wasn't wetting it enough. I ended up with a tremendous amount of texture. I had to remove the dip on those two tires and start over from scratch which cost me a lot of labor and time. Fortunately, time, patience, practice, and no less than a dozen you tube videos later, I was able to get results that I was pleased with. I used approx. 1 can of black per wheel and 2 cans of gloss enhancer. In all, it was 1 base coat, 4 wet coats, and 3 gloss coats. Now to be careful in taking care of them. Not sure how durable they are.
The wooden ones? Amazon.Where did you get that brush set?
I suppose you use those for the tight spots in the wheels...![]()
Perfect..!!!The wooden ones? Amazon.
I do use those on tight spots, but in paint. Usually around emblems, etc, and also when cleaning interior.
