MN5241
Just recently put in a level and went to the dealer to get it aligned. They gave me back in the sheet that showed how far off the toe/camber was etc, and where they corrected it. But it seems it now pulls to the right and if I return to "Center" the wheel is actually 10 degrees turned to the right. if I straighten it, it pulls left. Almost as if they put it back together with the steering not centered? I'm not too familiar with the process of this, but it doesn't seem right to me. This is my third leveled truck, and never experienced such a thing. It will be going back next week either way for other work and I will have them look at it again.
What you all think?
Thanks in advance!
Update: 2 days on the current alignment and it seems fine. I pulled the mudflaps off and no longer rub. However there is still a metallic clunk in the front passenger side, as if something isn't clearing on bumps while turning or is loose. I don't physically see anything, i crawled under and put my body weight into everything to see if I could find a loose spot, but nothing. I will have them investigate monday when I bring it in.
Another Update: So drove around a bit this morning, and I can consistently get the symptoms to occur. It seems very likely in the steering somewhere.
Heres a 3rd updates: found this service bulletin, https://www.dropbox.com/s/k2rdkokgd3ve381/Noise from Front Sway Bar Link.pdf?dl=0
Symptoms seem the same, however my truck build date was october 20th, either way I crawl under there, 18mm box wrench and 8mm socket, its loose...no means 68ftlbs, don't have the ability to get it tightened myself at the moment, or time, will look into testing this tomorrow.
What you all think?
Thanks in advance!
