2.5" Motofab lift with 35" ridge grapplers
PorBoy
Millville NJ
I see that one of your “ past “ mods was a Pulsar, may I ask what happened there ?
stax199
The shop me not to worry about the uca's because the angle isn't even bad.
thanks.. i was hoping I could just install these in my non ORG non air suspension without replacing UCA's.
rob989_69
Do you know, is there any clearance difference for 4wd? Love to run 35x11.5 or 12.5 if possible on stock 20's. Hard to find confirmation around here.
stax199
Yeah just check the angle of the ball joint cause you never know yours might not be okay.
thanks again.. so inspect the ball joint after install.. then decide to add new aftermarket UCA?
