psyberai
Clinically Abnormal Attention Paid To This Truck
U.S. NorthWest
I have to admit that, when possible, I am pretty lazy on my days off, however this truck has motivated me to make this a productive day off.
Replaced bulbs, except license plate and glovebox.
Removed 4x4 decals and replaced with Spiderman logos. Testing concepts for a future, professionally done, look.
Installed Amp Bedstep.
And applied some mirrored distressed flag decals to the shark fin. I think I underestimated how dark the fin was when I picked black gloss; and I might up to the next size and just trim.
Received my used, Ebay- bought, bed divider/extender. Definitely used, but I can bring back much of its luster, and it was relatively cheap at $255. We all know how ridiculously expensive they are new.
drush
Windsor, Ontario
Any water leaks with the MX4? I was almost set to pull the trigger on one until I started reading all the reviews that said it leaks pretty bad.
I’ve had good luck so far. No major leaks. If I spray water right at the tailgate seam then yes it leaks. No major downpours yet but I’m confident it’s good.
Techguy2000
Dallas, Tx
Am I correct in thinking that if you put a 50% film on the back windows (that are 18 - 20%), that will bring them down to 9 - 10% total?
Also, it seems like the front side windows are not perfectly 100% clear. Does anybody know what the factory tint level is on those?
Not scientific but my tint shop would not put a 25 on the front side windows because he said factory can measure 2-3 % so it would measure around 22 with a 25 film on (legal limit here in TX is 25). So 30 is the darkest they would go.
WasatchBack
Had my tire guy install wheels/tires since I couldn't figure out how to jack a truck up for 4 weeks. Happy with the result. Though the Ridge Grapplers drive a bit more trucky than I expected.
They look amazing. What year? factory, lifted or leveled? Wheel size, tire size?
WasatchBack
'19 Laramie I picked up 3 weeks ago, factory order. OE air, no lift/ no level. 20x9 Raceline Shift 930B /0 offset/275-60 Pmetric
I have the same, but no Air suspension. I’m really trying to get a bigger tire with a more aggressive look, like yours. It came with factory 285/46R22’s. They look like they should be on a sports car. Hate the look. No one seems to know what the largest I can go without a lift, adding 2” leveler would be fine.
Neurobit
RAM Sorcerer
Texas
Installed a protective case for the key fob (5 button).
FYI, the case is tight so have to stretch a little before it can be installed and slide it in one side at a time.
Thanks for the link. Just ordered one as well.
barakutha
You’ll like the Performance mode.
Installed last night. Performance mode is great, but I lost a bunch of functions on my radio like heat/cool seats, deploy/retract running boards, and Sirius XM..
Any ideas??
BeauxXL1200
[/QUO
Any ideas??
I lost some functions also but after riding around for ten minutes or so, I parked, turned the truck off, and restarted it and everything was back to normal. Hope you get everything back. If not, I would call them.
