Photo op
Just ordered Nitto Ridge Grapplers 285/60/r20s to put on my stock Longhorn wheels. Discount tire gave me $75.00 credit per tire for my OEM Bridgestones with 7,474 miles on them. I thought a $300.00 discount was a fair deal. Total out the door price was $1,228.50. Have an appointment Tuesday morning to get them mounted. I’ll post a few pics when they’re on the truck.
any pics?
They worked fine?
Here you go. I just did mine a few min ago.
It takes literally 10 min to do the swap (8 of those was figuring out how to pop the clear covers w/o damaging them). Basically, you need a real thin non-marring pry tool, and pry on either vertical edge. Pops right out. Once out, I waited until the lights went out after turning ignition off, and then swapped them out.
Ensure you check they light up before putting the covers back on. If not, flip them 180 deg and it will fix it (had to do that on the last one I put in).
Third pic shows the difference between filament bulb and LED. Night and day...
Cheers,
Can’t wait to see
Let us know if they rub on your stock 20’s
Will do. A fellow forum member put these on his Big Horn stock 20s with no lift or leveling, and he reports that there’s only a slight rub against the wheel liner material at full lock turns, and he thinks the liner material can be zip locked or pinned back out of the way. His truck looks great with these tires. Here’s a link to one of his his post.
Installed side steps on my truck today.
Installed the latest design (-AF) Mopar bedstep on my Rebel with Magnaflow Catback exhaust. Added a 3/16" thick washer under only the bottom bolt (between bracket and frame) to add clearance between step and the long 5" diameter exhaust tip. Fits perfect and only bumps exhaust if you let it close fast. Exhaust has room to vibrate without contact while driving. Nice heavy duty design. (y) :cool:
Modded together a bed extender from Harbor Freight and a set of j hooks to transport our two tandem kayaks (13.5'). Really happy with this!
3006830069
Replaced my cargo lights and 3rd brake light with the Diode Dynamics everyone's buying. Difference is night and day with the cargo lights. The pictures of the 3rd brake light don't do it justice just how much brighter it is. Well worth the cost to upgrade and literally takes 5 minutes. Pictures on top are before, and the pictures on the bottom are after.
That’s right. I’ve seen that thread. Post something if you come up with a remedy.
Will do. First, and assuming the rubbing occurs, I’ll need to pinpoint where exactly it rubs.
Ordered the borla touring with resonator, pulsar piggy back tuner, mx4 cover, and chrome Mopar deflector
Ordered Mopar Side Window Deflectors PN = 82215478. I am tired of the rain rolling into the cab if you crack the window ! bamwholesaleparts.com has them for 70.70 +shipping. 80.87 out the door.
First oil change at 2538 miles. PUP 5w20, Wix 57060XP, Fumoto F106SX.
  • Nels
