I know what you mean about the air being a hassle. I had the TSB done on my truck last week and a valve changed. Service dept said it was leaking. Got the truck back and it was worse. Still hot as can be and A/C lines have a constant hissing noise running through them.
Took the truck back in.
The service dept said the valve they replaced is no good and they need to replace the whole line now . Also now they found a leak in the expansion valve and will replace that.
