Patsy1099
- Jan 5, 2019
- Location
- People’s Republic of New Jersey
I'm back! Just got done replacing all the speakers all the way around. They sound nice but, as others have said there is a huge problem with my anc. I was looking back at the other threads and I lost where it went over how to disable it. I don't have an amp or one of the things like the dsr1. It's it possible to disable it without cutting so it's not permanent?
Yes you can disable it without cutting. I recommend you not cut it. You have a few options. See below.
1.) ANC stays connected: Go back and install your stock speakers and check the polarity of each one before removing it. Then reinstall the new speakers and be sure to match the polarity that the stock speakers had. In some cases you might have to reverse the polarity of the metra harness, either by releasing the pins and swapping them or by cutting the wires on the metra, flipping/resoldering. This is the most work but also your best shot at getting the speakers to work and not interfere with the ANC.
2.) Bypass ANC: you can unpin the ANC mic wires in the large white wiring harness. There is a thread explaining this if this is the route you want to take I can point you to it. Unlike cutting the wires you can easily reconnect.
3.) Bypass ANC: purchase the harness below and connect to the anc. It simply doesn’t have the anc mic wires connected in the harness so it is essentially unpinning them for you.
