12” Software update is out
Gman
Puyallup, WA
I'm not sure what's going on, but Apple CarPlay in my truck is working fantastically...again. It's even remembering the music app and station I used last.
SpeedyV
Ram Connoisseur
Fort Worth, Texas
Glad to hear it. Knock on wood, but mine’s always worked...and it’s a pretty sweet feature of the truck!
Buck
If you are in Nav there is a microphone at the top right of the screen that has never worked for anyone. It is actually grey and if you touch it nothing happens. Supposedly that function was due to be fixed at some point. I was wondering if anyone knows whether the TSB resolves this issue too.
I did the update. Helped with nothing !!
MJP
New Jersey
Was your CarPlay not working properly prior to the TSB? Mine works fine (knock on wood) without the TSB update.
cjmst23
For those who did the update....are you now able to remove or hide unwanted siriusxm stations? It's always been in the manual, but has not been in the setup menu anywhere.
Gman
Puyallup, WA
Mine just quit working correctly several weeks ago. I was having to launch Google Maps and Pandora before connecting to the truck. Otherwise, it would take a while before I could get both apps working correctly. Pandora also wasn't loading album art after the first song. I also had one episode where I connected the phone and shortly after the entire system restarted.
I haven't taken the truck in for any updates. I'm guessing it was either an app or OTA update (I'm leaning toward iOS app updates).
MJP
New Jersey
Gotcha
azzx
Central AZ
has anyone successfully done the upgrade in PHX area?
if yes, which dealership?
thanks
RBRK
Salt Lake City, UT
There has been an over the air update previously, you would think this one should be. Where is the system info screen found?
Gman
Puyallup, WA
I stopped by the local dealership today and they didn't have anything on a radio update.
trixdesigns
As with most TSB’s you’ll likely need to print it and bring it in with you. At a minimum have the full # to force them to look it up.
Buck
The TSB mentions voice recognition as one of the fixes. Does anyone know if that fixes the voice command feature in the NAV system that has been inoperable since we got our vehicles?
Did not help mine
Volkster
Clifton Park, NY
Seeing how a lot of you have several different common issues, before and after TSB update, and the fact that mine all seems to work good now, tells me it must be a hardware issue? Seems most logical
Willwork4truck
SC
I'd like to see that answer as well, as I haven't experienced these issues. Jan 19' build.
