Pressgrove
LUX Lighting Systems. I went with short bed and white
MAX Truck Bed Lighting
NOT made in China! Our under the rail LED Truck Bed Lighting set fits all pick-up trucks. Worlds first and only magnetic mounting makes lights removable to be used as work lights, back up lights, camp set up lights, running board lights, work van lights. 30 day 100% money back guarantee!luxlightingsystems.com
I loved the idea of magnetic mounting, but the Lux Lighting seemed a little steep to me. If I was putting it under the truck, I would pay up. Under the bed rails is pretty low risk (in my opinion, anyway).
I opted to make my own magnetic mounts. I purchased these lights and these magnets from Amazon. Both have adhesive backing, so I was sticking adhesive to adhesive which worked really well. The magnets are really strong, and the LEDs are available in different colors if that's your thing.
The light kit came with four per side, which would be perfect for a long bed. For my short bed, I removed one light from each side; there is a connector (in photos) between each light so it was really simple.
I opted to go through the front stake pockets (or where they would be). I have a Bedrug so the wires were easy to conceal. I crossed the passenger side wire through the frame rail to keep it clear of the exhaust and drive shaft. There is a slight risk of the wire rattling in that cavity, but I doubt you'd ever hear it with the vehicle in motion (I'll report back if it turns out to be a problem). I would not use this method if you don't have rear wheelhouse liners, as the wiring would be too exposed. I spliced into the cargo light wire in the back door jamb and grounded to a body panel support bracket that was easy to get to (I put dielectric grease on all of the connections except the one in the cab).
I replaced the factory cargo lamps (and 3rd brake lamp) with LEDs from Diode Dynamics. These can be had cheaper on Amazon, but some have had issues with key fob interference with those. So far, the reports on the Diode Dynamics LEDs are all good (and so far, no issues with mine either).
All up and in, I'm still <$100 and am very pleased with the result.
