WESTIN PRO TRAXX 5" Wheel to Wheel Step Bars
I wanted to chime in on the Pro Traxx 5" wheel-to-wheel step bars.  Finally got them on - I say finally because the install was confusing at best. I really wanted the wheel to wheel version this time for better access to the front of the bed because with my previous trucks I would stand on the edge of the normal length step bars and stretch sideways, not great.  There weren't many reasonably priced setups for this - went with Westin 5" Pro Traxx for $316 form a vendor on Amazon.  The Amazon prime price was a bit more I think.
I'll post photos.  I did not use the last bracket (#4 of 4, connects to the underside of the bed) because it didn't fit my truck.  The Ram has a large round mount sitting in the way of the Westin drop-down piece. My weight 190 lbs, so stepping on the rear edge of the step bars without that last bracket causes a small amount of flex in the bar but I can live with it.  The other 3 brackets are connected to pre-existing studs which seem to be only sheet metal/reinforced sheet metal, not frame mounted.  I'm going to call Westin and inquire about that last bracket, but will probably leave it with only 3 brackets per side.  The rear brackets alone weighed 39 lbs!  I never had 39 lbs of leftover parts before lol.  Anyway, the following photos show: 1. the final product, 2. the instructions showing where the rear bracket is attached to the bed underside, 3. the actual bracket attached to the underside but having a bed mount in the way, 4, and finally the box pf leftover parts:
