No problem. Right now from top center wheel to liner it’s:
Front- 6 1/2”
Rear- 9 1/4”
I talked to them today and they are ordering the parts. I'll try to take before and after pictures. Also measure.
Service guy asked how I knew about it..."5thgenrams.com man!".
Something that has been asked is were you charged for the additional spacer or since it has a TSB did Ram cover the parts/labor? Want to answer another user in a separate thread that inquired.
Thanks!
Got the spacer for free. Had to show receipt from Mopar. Install was not free since I had another shop do my Lift.
Got it, so TSB cover's parts/labor if install was done at factory. Thanks
Front- 6 1/2”
Rear- 9 1/4”
Just got the updated Mopar spacer and ORP springs installed. Definitely looks better. Seemed to raise the front about 1 3/4”. It’s now
Front- 8 1/4”
Rear- 9 1/4”
Awesome. Thanks for the update. I’m really happy with those numbers. Looks like the ORP springs with the Mopar lift create a nice all-Mopar lift that is closer to level. I was thinking of adding the .5” Motofab spacer on top of mine. Any opinions on that? I don’t want my truck looking nose-high. Just out of curiosity, do your UCAs look good?
I’m definitely not mechanically inclined unless it’s a pencil. So I’m not sure how the MotoFab spacer would do or even my UCA. I did ask the installer about my UCA and he said they look fine. For a piece of mind I may wait on Ready Lift to sell the UCA for the their 4” Lift separately and have those installed. The ride seems to be the same as before so there’s no difference in that. I’ll take some pics when I get home.
Thanks. I will look forward to seeing pictures. There are so many different angles on these trucks that for me, it’s hard to determine what to judge from when deciding whether the truck looks level - The wheel wells? The bottom rail? The top of the bed? The cab top? When you look at your truck, does it look level to your eye? Slight rake? Thanks for being the guinea pig on this!
The Mopar/Fox lift kit comes with replacement UCA's that are designed specifically for the added lift - so needless to say, they look great! Forgot to post these earlier..
IMO the Mopar lift is perfect, i'm not sure i'd want it any higher as then the tire would not fill the wheel well out as designed. And the 6" lift with 37's looks BADASS but the MPG I can't imagine would be worth it.. Mine is pulling 11-12 city with 3.92 on 2" lift with 35s on 22s currently on 600 miles...
View attachment 23141View attachment 23142
Tried to put it on as level of a surface. For me this is exactly what I want. I thought about 35” tires but went with 305/55/20. Just over 33”.
Looks good skol. I wonder how much each part added. My parts are ordered so I guess it's a matter of time before I find out.
Looks great. I will be skipping the.5” spacer. I run the same sized tires but on 18” wheels (275/70R18). I have the Big Horn without the fender flares, and I don’t want the lift to make the wheels look undersized. I will post pics when mine is done - hopefully by the end of next week. Thanks again. This is great.
