The two in body vendor had me questioning how they build the RamBox versions. Obviously the spray in bedliner goes last so I'm thinking they go through the normal factory with just the steel bed and gaping holes where the inside sidewalls are missing along with the RamBox lids. Then someone (maybe the body vendor?) installs the RamBox plastic box from the bed side and then the screw on the steel inside side walls?
Would be great to see a video of them being built. Possible a DS RamBox build video exists?
I've also wondered how they would repair a cracked plastic box once built. That also leads me to wonder what other room is available inside those removeable inside side walls under and around the RamBox boxes?
