Runningwithbeers
 - Mar 10, 2019
Added some rough country fender flares still waiting on some more weather stripping to finish them off on the other side.
	Did a little mileage test today. Got a video below with some RPM data for those who may be curious about 3.21s, but overall got a little over 20 mpg hand calculated. Trip odometer was a couple of MPG off. Had a strong headwind. Otherwise, I think I could have gotten better.
Replaced the chrome lug nuts. Why they make a "Blackout" package that removes all other chrome and leaves the chrome lug nuts is mystifying to me.
Looks sharp! What fender flares? (Can you put your details in signature?)Done. 3.5 inch SST lift, Fuel Rims, 35" Nitto Grapplers, OEM auto steps , Flowmaster super 50, Bora 1" spacers, Stryker 955 10 Meter w/ 102" whip antenna. Ordered all the parts for oem trailer brake module, thanks to a previous post for 112.00 from mopar parts. Dealer say's 80.00 to install. Done.
What side steps are those?Added 1.5” wheel spacers. No trimming of the studs and no rubbing of the tires.
Nice!I knocked out my BAK X4 revolver and my HDX running boards.
Bay Area, California- 2019 RAM 1500 Laramie Crew 4x4, 5'7 Bed, Granite Chrystal, E locker, Black Interior, 5.7 Hemi, 3.92 axle, Level 2 Equip Group, 12in NAV, Advanced Safety Group, Pano Sun Roof, Bed Utility Group, Air suspension, Off Road Group, 20X9 +1 Fuel wheels, 275/65R20 Nitto Ridge Grapplers, Deployable bed step, 33 gallon tank, Ram Box, Trailer break control, Mopar Slush Mats.
What offset are your wheels?Done. 3.5 inch SST lift, Fuel Rims, 35" Nitto Grapplers, OEM auto steps , Flowmaster super 50, Bora 1" spacers, Stryker 955 10 Meter w/ 102" whip antenna. Ordered all the parts for oem trailer brake module, thanks to a previous post for 112.00 from mopar parts. Dealer say's 80.00 to install. Done.
EGR's from realtrucks.comLooks sharp! What fender flares? (Can you put your details in signature?)
Dealer installed oem auto steps.What side steps are those?
1 inchWhat offset are your wheels?
The Line-Ex was actually done on Monday, but I took the photo today. I also had the bumper and fascia wrapped with XPEL this morning.
They're Westing HDX Xtreme side steps. I love them! Got them on Amazon https://amzn.to/2uNarwKWhat side steps are those?
I quoted the other guys side stepsDealer installed oem auto steps.
Can you post a picture from the side? I'm trying to see how tight they tuck to the bodyThey're Westing HDX Xtreme side steps. I love them! Got them on Amazon https://amzn.to/2uNarwK
 Last night in the dark I added the LOMAX Tonneau cover (30 min alone), Weather Tech mid guards (1 hr alone), and installed the brackets for the GoRhino D6 Dominator steps, at that point it was time for sleep. Will finish this afternoon and update with a picture.Very easy actually:
1. remove the 4 screws that attach the high mounted brake/cargo light to the cab
2. unplug the wiring harness that attaches to the light assembly
3. unplug the center brake bulb and remove the bulb
4. attach the ground wire from the strobe module to the black wire of the brake bulb socket
5. cut the white wire that powers the brake bulb and splice in the two red wires from the strobe module (connector wire to INPUT side of strobe module and socket wire to OUTPUT side of strobe module)
6. Install the LED bulb into the brake light socket
7. reconnect the truck wiring harness to the light assembly and insert back into the cab
8. reinstall the 4 screws to securely mount it
9. have someone get in the cab and press the brake pedal while you watch. You should see 4 rapid flashes...then 4 slower flashes and then it remains on steady as long as the brake pedal is depressed...done! See the video on their website for what it will look like once installed.
*** you MUST replace your incandescent brake light bulb with an LED bulb for this to work correctly. I bought the following off Amazon and very happy. Bought 4 so I can use 3 to replace the 2 cargo lights and the 1 brake light with 1 to spare:
Amazon.com: LUYED 2 X 1550 Lumens Extremely Bright Error Free 360-Degree Shine 921 912 W16W 3030 24-EX Chipsets LED Bulbs Used For Backup Reverse Lights, Xenon White: Automotive
Buy LUYED 2 X 1550 Lumens Extremely Bright Error Free 360-Degree Shine 921 912 W16W 3030 24-EX Chipsets LED Bulbs Used For Backup Reverse Lights, Xenon White: Back Up Lights - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
I soldered and shrink wrapped each of my connections but you can use butt connectors as well. Took about 30 minutes from start to finish. Works great and I am very happy with the result. I strongly suggest you buy from SuperBrightLEDs as the reviews were excellent and you get a 3-year warranty. $4.95 plus shipping...can't beat that!!!
Instead of cutting wiring harness, I found a bulb the plugs right and and does a quick 3 flash then solid, three colors to choose from also....
here is the amazon link :
https://www.amazon.com/gp/product/B07JKDKW66/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
