Shopped around for tires all morning. Got quoted $880 out the door for Nitto Ridge Grapplers, sizing up from 275/55r20 to 275/60r20. Probably gonna have to run with that. I think tires and front tints are next on the list.
I added the snapshot of them just look up 2019 ram emblems for RAM black emblem and 2019 Ram overlays-seller is rebeldecals he carries the color match over lays
Yes I changed the chrome emblems to black and then added the overlays on top of black.
Thanks brother
I used a very thin knife to pry them up. I started at the corner of each letter and worked my way around. With the "A" I had to use a small chunk of bark as a spacer to help keep the top portion pulled out while I worked on pulling out the bottom. Just remember to take it slow.
Thanks!! Also, do you have the part numbers for the letters, or were these aftermarket?
Put some black hood badges on, and color matched ram letters up front. Going to debadge the rest of the badges and going with a black rams head on the back. Hopefully that will be here today or tomorrow
Went to pick it up at dealership, had to leave it with PPF guy to fix a bubble.21049
Got my truck back after clunking. So far so good, just needed to tighten the sway bar end links.
Got my power running boards installed and work great other than a small vibration/humming in the steering wheel since they were installed. Couple users recommended that I rotate something away from the frame, but it's not touching... so not exactly sure on that part.
Anyways, now I just need to look at mufflers. The mid-range borla seems a good option, but still a big price.
Where did you order it from?
Mishimoto.....
That's a big bubble.. little bubbles will work them selves out in a week or two..
Had mine fixed yesterday but mine was peeling.
They are redoing the entire lower bumper, there were a bunch of smaller bubbles all over that they worked out but couldn’t fix that big one. The manager said he’s be pissed if it was his truck and told his guys to redo the whole thing, good but sucks cause I was hoping to take it home today ha.
Today I switched out the interior lights to LEDs. They made a huge difference over the yellowish stock bulbs.
Same here.. Entire lower bumper, took them about an hour.
  • Back
