Rusty like I stated above all this is a 2019 Ram 2500 frame assembly, and rear axle with design change's done to the frame assembly to accommodated the 2019 Ram 1500 cab/bed assembly with what appear's to be AEV Ram 2500 fender flares/ and 18 inch simulated beadlock wheels running BFG 35X12:50X18. So we are stating a 215mm front axle is running up from front with a 3/4 ton rear axle with 3:73 or 4:10 gear ratio's.This design in no way shape or form comes even close to the 2016 Ram 1500 Rebel TRX.I would hope that Jim Morrison speaks out about this cheap version of the Rebel TRX.With Fords 2019 F-150 Raptor at a price point of around 78,00-87,00 this is a cheap knock off to gain higher transitional price points for Ram in the 1/2 ton market, a goal that FCA set back in 2017. The Rebel TRX needs it's own body panels much like Ford does with it's design, Ford also does not run a Raptor on a 3/4 ton frame nor a 3/4 ton axle assemlies.FCA Ram is using the same motor mount dimemsion's for there 6.2 gas motor for the Hellcat 6.2L SC motor.I do not approve of this myself personally I find it a insult to the 2016 Ram 1500 Rebel TRX and the Ram engineer's who came up with a viable competitor against Ford's Raptor program. One only needs to look at Jim Morrison's interview at the 2016 Texas State fair when ask by Roman from TFL Truck when Jim stated "he hardly thought that the 2017 Ford F-150 Raptor was any competition for the Rebel TRX".Also he also stated that he had instructed Ram engineering to come you with a pre-prduction ready 100 mph off road pre-runner.The press will have a field day with this if they bring this to market FCA will have that saying "cheap Italian knock off" not to mention a insult to the hard work put in for the development of the 6.2L Hellcat motor.Sorry guys just ain't feeling this design for a TRX,no way would I spend 80,000 dallors for it.
