securityguy
Same here!
			I also got a tracking number for delivery Wednesday.Got my notice from FedEx saying it will be delivered Wednesday
I would help out more guys but the deal is over. If there will be another group buy i will update. Thank you.
Well that's disappointing. I'll confirm when I get mine. The Pulsar trumps this gadget if they are too big of a hassle together.So you cannot control the tazer at al with the pulsar installed. Gotta remove it. Set the non live features with the tazer. Remove it and re install the pulsar. Unless someone else got it to work all I get when both are installed is a searching message.. or it could say programming I forget.
Mine engages quite often, and with the Carven it drives me crazy.With an aftermarket exhaust the drone is terrible when mds comes on
Why not pull the Pulsar out. Make all your changes and settings you want on Tazer. Then install Pulsar and just use the right side to change pulsar modes . ???Just got it. Plugged it in at work. It doesn't interfere with Pulsar but Pulsar interferes with the display. The Pulsar operates as expected. Tazer DT will flash the menu item then Pulsar quickly overwrites it. They are both writing to the same interface, which I expected. I was hoping the Pulsar would ignore Left Arrow+Cruise keys like the Tazer DT ignores Cruise only keys. A solution would be for the Tazer DT to delay it's write until after the Pulsar. Everything would work correctly then.
I don't think I successfully "married" it since I can't see the menus. Looks like I'll have to either have to uninstall or pull the fuse on the PCM to make it work. Too bad the ZPU software can't be used to make my settings. I'll know more this evening.
I wasn't clear. Yes, I'll either need to uninstall the Pulsar or pull the PCM fuse. Not sure pulling the fuse will work since some of the settings may reside in the PCM and the Tazer DT might not be happy with it missing. We'll see.Why not pull the Pulsar out. Make all your changes and settings you want on Tazer. Then install Pulsar and just use the right side to change pulsar modes . ???
I had to uninstall the pulsar then I was able to set the tazer settings. Hopefully they see a lot of us want to run both and update the software.I wasn't clear. Yes, I'll either need to uninstall the Pulsar or pull the PCM fuse. Not sure pulling the fuse will work since some of the settings may reside in the PCM and the Tazer DT might not be happy with it missing. We'll see.
Just talked to the guy today and he’s getting a pulsar so he can try and make them work togetherUninstalled the Pulsar and everything works. I enabled Video in motion and disabled Fog Light dropout on High Beams and mapped the Resume button to display the Backup Cam (Sorroundview screen). Works perfect.
Live Functions like line lock and high idle (winch mode) work great. 0-30 and 0-60 work great also. Light Show is cool!
I'm leaving the Pulsar off until I get my 2 recalls done. I'll report back after I reinstall it.
That's awesome. I deal with programming embedded controls for work. The fix looks simple. Add a short delay to display writes so it overwrites the Pulsar instead of the Pulsar overwriting the Tazer DT.Just talked to the guy today and he’s getting a pulsar so he can try and make them work together
You should message zautomotive on Facebook messenger and tell him that. Might help? But the guy is probably already pretty good at programming also lolThat's awesome. I deal with programming embedded controls for work. The fix looks simple. Add a short delay to display writes so it overwrites the Pulsar instead of the Pulsar overwriting the Tazer DT.
