TAZER DT for 2019 RAM 1500
WasatchBack
Ordered thanks for setting this up. Now just have to order my truck this week.
whetrick1
I would help out more guys but the deal is over. If there will be another group buy i will update. Thank you.
And thanks for setting this up for everyone. I think it's going to work great.
M
Mdegen93
Guest
So you cannot control the tazer at al with the pulsar installed. Gotta remove it. Set the non live features with the tazer. Remove it and re install the pulsar. Unless someone else got it to work all I get when both are installed is a searching message.. or it could say programming I forget.
ExcursionDiesel
Well that's disappointing. I'll confirm when I get mine. The Pulsar trumps this gadget if they are too big of a hassle together.
myram2019
Got mine, plugged it in. Does exactly what is say and easy to use. Let me know what you guys think.
Cmerkert
New York, US
Got mine yesterday. Very excited, but since my truck is currently in JB, I guess I will have to just plug it into my butt until my truck arrives. :oops: LOL Check that! Ram Chat literally just told me KZ today. Sorry Butt, hold the phone!! lol
ExcursionDiesel
Just got it. Plugged it in at work. It doesn't interfere with Pulsar but Pulsar interferes with the display. The Pulsar operates as expected. Tazer DT will flash the menu item then Pulsar quickly overwrites it. They are both writing to the same interface, which I expected. I was hoping the Pulsar would ignore Left Arrow+Cruise keys like the Tazer DT ignores Cruise only keys. A solution would be for the Tazer DT to delay it's write until after the Pulsar. Everything would work correctly then.
I don't think I successfully "married" it since I can't see the menus. Looks like I'll have to either have to uninstall or pull the fuse on the PCM to make it work. Too bad the ZPU software can't be used to make my settings. I'll know more this evening.
myram2019
Why not pull the Pulsar out. Make all your changes and settings you want on Tazer. Then install Pulsar and just use the right side to change pulsar modes . ???
ExcursionDiesel
I wasn't clear. Yes, I'll either need to uninstall the Pulsar or pull the PCM fuse. Not sure pulling the fuse will work since some of the settings may reside in the PCM and the Tazer DT might not be happy with it missing. We'll see.
M
Mdegen93
Guest
I had to uninstall the pulsar then I was able to set the tazer settings. Hopefully they see a lot of us want to run both and update the software.
azzx
Central AZ
One of the listed features is this: "Disable camera lockout – use the backup camera and/or added cargo/front/undercarriage camera at any speed for any length of time"
So, if I add a front or front and side cameras I can activate it using Tazer and it is displayed on the Uconnect screen?
and, I will not need the sales code to turn the cameras on?
ExcursionDiesel
Uninstalled the Pulsar and everything works. I enabled Video in motion and disabled Fog Light dropout on High Beams and mapped the Resume button to display the Backup Cam (Sorroundview screen). Works perfect.
Live Functions like line lock and high idle (winch mode) work great. 0-30 and 0-60 work great also. Light Show is cool!
I'm leaving the Pulsar off until I get my 2 recalls done. I'll report back after I reinstall it.
M
Mdegen93
Guest
Just talked to the guy today and he’s getting a pulsar so he can try and make them work together
ExcursionDiesel
That's awesome. I deal with programming embedded controls for work. The fix looks simple. Add a short delay to display writes so it overwrites the Pulsar instead of the Pulsar overwriting the Tazer DT.
M
Mdegen93
Guest
You should message zautomotive on Facebook messenger and tell him that. Might help? But the guy is probably already pretty good at programming also lol
