Headlight bulb replacement - Bighorn
You don't need anything so expensive
Low beam h11
Fog h11
Highbeam 9005
Reverse 7740
Cargo lights 921 you need 3bulbs
Inside
Map light T10x2
Glovebox T10
Floor 2x T10
Dome 41/42mm
Alla Lighting CANBUS 578 LED Bulbs White 800 Lm Extremely Super Bright 6000K Xenon LED 578 Bulb 41mm(1.72") 3030 SMD 569 211-2 212-2 578 LED Interior Festoon Map, Dome, Trunk Lights (Pack of 4) https://www.amazon.com/dp/B0784WH9DD/ref=cm_sw_r_wa_apa_i_BpYFCb3179CJ7
I have qty 3 921 bulbs for the back cargo lights CANBUS compatible if anyone wants them. I'm in the Detroit area if someone wants to meet up, or if you PayPal me for shipping I'll drop it in the mail. Send me an email to [email protected]
I just ordered these bulbs after talking with Lasfit. Here are the links on amazon to the bulbs:
High Beam:
https://www.amazon.com/gp/product/B07JQ6YTJB/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Low Beam:
https://www.amazon.com/gp/product/B01N3333R1/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
They will be here on Thursday, and I'll let you guys know how they are.
Thank you! I just returned my headlight revolutions bulbs. Please send pics installed! Btw lasfit sells switchback led bulbs for your turn signal.. VERY clean look and its about $70 no resistors needed! 2min install!
I’m getting my switchbacks tomorrow. I’ll update Friday on how they work.
Did you get these installed?
Sent from my MI MAX 3 using Tapatalk
They also sell the switchback lights for fog lights as well, they will kick from yellow, to SOS to white. Pretty slick, if you go to their YouTube channel you can see them installed
Terrible picture, but I have the Beamtech LEDs in the low beams and GP Thunder 3500k bulbs in the fogs.
LEDs have better output than stock, have the same cutoff line/height as stock from what I can tell, and do not throw any codes. I paid $38 shipped for them on Amazon. I couldn’t justify paying the $160 plus for Headlight Revolution. The fogs are regular halogens and were $16 shipped on Amazon.
Overall, I think it is a much better look for about $50. Sorry for the bad pic. I’ll try and get a better one this week. It looks like the lights are glaring, but that’s not reality. Just some iPhone camera nonsense. I haven’t been flashed once since installed them last week.
That company is reselling from china, they don't even make it, just good advertising.
Just arrived! About to install/test now.
All good! No errors codes. They function normally. Will check again tonight to see how bright they are.
Here are a couple more pictures.
Here they are night time after install. You can see the difference between the LED and the standard halogen low beams and fog lights. Switchbacks work like a charm!
Any updates? The LED low beams will probably be my next purchase/install.
Got into a bit of a mix up with Amazon and Lasfit in regards to these bulbs. Long story short the correct bulbs will be here on Monday. I cannot day enough about Lasfit customer service. They handled everything and avoided the whole amazon path. The low beams are not available until next week, because of the mixup; they sent me the new one before official release but only a few days early. I’m excited to get them and install.
Which lowbeams did you go with? I noticed on amazon they have the wrong ones listed.
So with the switch back turn signals, do they stay illuminated white all the time and turn Amber when the turn signal is activated? Since these trucks use low beam as the drl's I'm confused as to what the switch back accomplish
My understanding is that is exactly how they will work. White light until turn signals are used, switching between white to amber and back. Hence the name.
What is the power source that keeps them glowing white until the turn signal is activated? If no turn signal is on, that bulb should be off.
Oh good point. I take back everything I said. I know nothing.
Nevermind. Realized these will just give you white running lights instead of Amber. Nothing to do with the DRL's
